Author Topic: rear bumper bolt questions Dearborn 69  (Read 1057 times)
Offline acman63
« on: May 13, 2015, 05:54:02 PM »
which bolt is correct?   left or right
Offline 7Lscjracer
Re: rear bumper bolt questions Dearborn 69
« Reply #1 on: May 14, 2015, 02:57:13 AM »
So the bolt on the left has a captive washer?
Looking at things logically, that would be the one.
Never seen a flange head bolt used with a washer since it's redundant.
The footprint of the flange head bolt alone is too small for the application in question
« Last Edit: May 14, 2015, 03:03:07 AM by 7Lscjracer »
Bought May '81, sold Sept '20
« Reply #2 on: May 14, 2015, 03:33:30 AM »
That type of flange head and washer are commonly seen used on the 67-70 convertible skid plate except washer typically has serrated edges. Makers mark varied .
« Reply #3 on: May 14, 2015, 10:12:56 AM »
N bolt on left used rear bumper & tie down brackets bottom hole & usually phos.   The other right side bolt was usually only used on firewall 4 bolts holding export & shock tower braces .
« Last Edit: May 14, 2015, 10:17:45 AM by specialed »
