Author Topic: fixation screws latch folddown seat  (Read 1888 times)
Offline Fastback2013
« on: May 13, 2015, 08:53:37 AM »
Hello,
Can somebody confirm that these screws (picture in attachment) are the correct ones for the fixation of the latch for folddown seat on a fastback?
In the Osborn manual it says : '55590-S2' but I don't know what it stands for, or look like.
Thanks for the help.
Regards,
Jeroen
San Jose 7R02C1708xx
Fastback GTA
built on 01/12/1967
Re: fixation screws latch folddown seat
« Reply #1 on: May 13, 2015, 04:41:12 PM »
Jerone,
 If you go to the Library Section of this forum and open the post titled "Mustang Hardware Spreadsheet 67-68", open spreadsheet titled "MHW67-68PN01", scroll down on the left hand column, "Part Number" to the part number you need, you will find a description of the part including the reference document where it came from. File "MHW67-68AP01" lists the hardware by application. Give it a try.
« Reply #2 on: May 14, 2015, 03:07:53 AM »
Don't believe you will find that they used screws in those holes - they didn't other years.   Looks like the same hex headed small bolts heat treated - dark finish for this years and the earlier ones
« Reply #3 on: May 14, 2015, 06:42:52 AM »
+1 the dark hex head matches what I've seen, had, and have.
« Reply #4 on: May 14, 2015, 11:54:59 AM »
Thanks for your answers.
I must admit that I am not a specialist in screws  ???...
Is there a sort of tutorial where someone explains what what is?
Those screws are black, so that is correct.
But hex head?
Sorry for my ignorance....
Jeroen
Fastback GTA
built on 01/12/1967
Offline WT8095
  • Dave Z.
« Reply #5 on: May 14, 2015, 12:22:33 PM »
But hex head?
Jeroen
AMK's website is a great place to start. The intro section to their catalog explains nomenclature for various types of fastener features and how to measure them:
http://www.amkproducts.com/Catalog_PDF/FC-5.pdf
Their site also has photos for nearly every fastener they carry. To follow your reference, you can see a photo of 55590-S2 as specified in the assembly manual. I don't see a search feature on their website (someone correct me if I missed it), but you can use Google to search their site for a specific OEM (e.g. Ford) part number.
Dave Z.
« Reply #6 on: May 14, 2015, 07:00:40 PM »
65 example showing the head and intergrated washer from a better angle. The rest of the shape is a fine thread small dia bolt
« Reply #7 on: May 14, 2015, 09:46:10 PM »
Here is what I have on my 67, and what I recall seeing on others.
« Reply #8 on: May 15, 2015, 01:44:51 PM »
Thank you all for the offered explanation and help!
It was very learnfull.
I will order the correct ones.
Again, thank you.
Kind regards,
Jeroen
Fastback GTA
built on 01/12/1967
