So far, yes. However to me it is still unclear (see drawing) where the measure 14" goes from the right clip to the left side (endpoint)? Its in the middle of "nowhere".
The potential collision described.
Another thing which needs to confirmed and possibly attached to the drawing. What is the position of the first clip hole (mm) rocker panel downwards? 9/16? 7,94mm?
But would be great to update your drawing as you mentioned.
And if smb could sell to me the total original (and functional) set of clips incl. fender clip and stud....nice.
Thx
Ralf
First thing I wish to mention before responding to the questions I see Ralf may still have, I have tried to supply only the forward and aft measurements that would
for all 6 of the riveted clips to ALL be placed downwards equally from the marked on line. If it were me installing RPM on a car that has had a rocker panel replacement OR a car that did not come with the moldings, I would place a rocker panel molding into the correct "finished position", then, using a fine-tip "Sharpie" marker (or similar) for scribing that top line onto both the rocker panel and the fender of an already ASSEMBLED car. I don't feel that using another example (such as mine) and taking those measurements to establish this horizontal line would be the best idea. The idea is to get the RPM aligned PARALLEL, barely below the corner edge of the rocker panel itself, this along the full length of the rocker panel. Keep in mind, it is not impossible for a RPM produced from a different time period or different manufacturer, for those moldings to be exactly identical. Using the measurements copied from another example COULD possibly cause an installer issues of fitment. Proper "installed positioning" would be far more important than matching those numbers precisely.
It might be wise to use the measurement instructions that are supplied in the Ford document Marty supplied to do a TEST on only ONE of the riveted clips TO VERIFY the best location to set the horizontal line of all 6 of the top rivets. (suggested as APROX. 5/16" below top edge of molding) Be careful and assume NOTHING before punching all of the holes in, ONE mistake hole would be bad enough so TEST, Test and double check before drilling all of your holes. I might do my "test hole" for one of the clips somewhere in the center of the molding, screw the clip (I would not rivet it) temporarily on using only the top hole, snap the molding on temporarily and see if it sits where you want it in relation to the top of the rocker panel. If it is off a little, you'll then know which way to adjust (up or down) make the correction and try again. Hopefully, you get it right first time, if not, you have only one mistake, fill the mistake hole (if you have one) with a body sealant and move on.
(NOTE: to prevent any scratching of your paint, I do think the initial "marker line" should be done with the front stud removed from the rocker molding, so the molding fits against the panels completely. Also a very good idea to have a 2nd set of hands for this to keep the long molding from shifting while scribing the line ~The stud gets installed after the hole for the stud gets drilled)
1.)
The 14 inch measurement is a perpendicular measurement from the rear edge of the fender, to the top rivet hole of the forward most of the 6 riveted on clips used. (5 clips on the rocker panel, the 6th is on the fender adjacent to the stud clip)
2.) All top holes for the 6 rivetet clips
would run the same distance downwards from the scribed line3.) Without having my example with a fender in place at this time AND a scribed line as previously outlined,
I would not have an accurate "downwards measurement" from the scribed line available for the forward most stud hole, only the measurement from the edge of the fender, going forward to the center of the hole for that one.
That measurement on my example is 15-3/16" from the edge of the fender.
I sincerely feel that the holes on different examples very likely will NOT match EXACTLY other cars, these molding are installed AFTER FINAL ASSEMBLY so to match where a factory worker drilled holes in the fender using other examples as a basis, is in my honest opinion , A HUGE MISTAKE. A person needs to use his a her natural skills of the trade at this juncture, not some sort of "template design".
To me, these measurements ought to get you into the ballpark (American for "close enough") to understand how it was originally accomplished.
I hope all this helps others, I am honestly exhausted about this topic.
