Author Topic: original '67 289 radiator identification  (Read 9327 times)
Re: original '67 289 radiator identification
« Reply #30 on: December 05, 2018, 06:59:51 PM »
The extra cooling on a Shelby consists of the radiator as Kurt noted, the shroud (rectangular and oval FoMoCo logo, depending on date) and a slightly larger diameter 4 bladed fan.
I'm also seeing a plate just below the radiator water inlet with a round hole. I thought this was indicative of an original core, but I'm unsure. Can anyone verify or disprove?
You forgot to mention the fan spacer which was a different length on a extra cooling radiator car.
« Reply #31 on: December 05, 2018, 07:26:30 PM »
I did and it's only 5 feet from me!
Hopefully mine is stock. It has a number 2 above the Dorman wings and has a circled Ford logo on the nose (or pilot).
« Last Edit: December 05, 2018, 07:28:44 PM by Bossbill »
« Reply #32 on: December 06, 2018, 03:48:25 PM »
C4AE -8546-F is the correct one used on the 67 GT350 without AC ,however there are no engineering numbers to identify it and more then one MFG too. 2.74 is the correct measurement . Most owners make the mistake of using the 2.36 one typically used on the hipo. The correct one is visibly longer and easy to tell when looking at a car. I forgot to say a made up a few to have on the shelf.
« Last Edit: December 06, 2018, 03:50:38 PM by Bob Gaines »
« Reply #33 on: December 06, 2018, 08:55:56 PM »
That part number jives with my Vehicle Order sheet for its DSO (84-2571).
It's odd that the MPC says "including pilot", since that's not a very good measurement.
One would think the dimension would be machined face to machined face, but including the pilot works well at the parts counter.
I have the 2.74 version including pilot with about .04 being the Ford script!
« Reply #34 on: December 06, 2018, 10:51:35 PM »
The important measurement is machine face to machine face because that indexes the the position of the fan blade but I don't make the rules.
Offline Deuce
« Reply #35 on: December 08, 2018, 10:04:15 AM »
... The main difference in standard vs extra cooling radiator was in the fins per inch specification and otherwise look the same.
Can anyone comment, for 1967, the difference in fin-count-per-inch between Standard and Extra Cooling W MO radiators?
(Here's a recent forum thread related to the above question: 1967 Extra Cooling http://www.concoursmustang.com/forum/index.php?topic=18897.msg119384#msg119384. )
« Last Edit: December 08, 2018, 12:43:43 PM by Deuce »
Deuce
« Reply #36 on: December 08, 2018, 03:46:26 PM »
My comment is that I believe the default replacement cores available are of the higher fin count per inch .
