Author Topic: '66 automatic transmission lines clip/alternator/neg battery cable attachment  (Read 1729 times)
Offline socalgt
I'm looking for the original sequence of attaching the (automatic)transmission cooler lines clip, alternator wire and negative battery cable to the stud in the block on a 289.  If I remember correctly from removing them....stud, alternator wire, negative battery cable, cooler lines clip, lock washer and nut? alternator, negative battery cable, lock washer and nut?
Offline suskeenwiske
  • 214-347-3628
I'm sure that someone will have the answer and maybe haven't responded because they somehow missed your post.
I found conflicting information which may have to do with where the car was built or just that the information is incorrect.
The most common order that I found was Transmission Line Clip, Alternator, Battery Cable, Washer, Nut.
Let's hope for an informed answer as I didn't find anything definitive.
Ray
Ray
1965 Dearborn Coupe
6 Cylinder, AT, PB, PS, AC
Est. Build 23A
Where and when was your car built?   Might make a difference and just might have pictures from same plant around the same time.
Think this was discussed before - Did you do a search?  Might have been for 65
Sometime in 1966, a stud was used instead of a bolt for the battery ground on small block V8 engines with an automatic transmission. In general, the arrangement was: block; external tooth lock washer; battery ground cable; alternator ground cable; stud; AT cooling lines bracket; jam nut (Ref: Ill sect A71 pg. 6). This is Ford service assembly criteria. It implies that the battery and alternator were grounded first, then the AT bracket installed. I, personally, do it this way: block; AT cooling lines bracket; stud; battery ground; alternator ground; external tooth lock washer; jam nut. I do it this way as I've replaced more battery and alternator ground cables then AT cooling brackets. The real answer lies whether, on an AT engine, the alternator and battery ground were installed before the transmission. This is speculation, the alternator and battery ground installation could have included the AT cooling line bracket, which is close to the 1965 and earlier method that used a bolt. (I also use an additional external tooth lock washer at the block, it's the EE in me, always redesigning.)
Offline ChrisV289
What is the correct finish for the bracket that holds the transmission cooling lines?
2009 V6 Mustang Coupe
Offline slk25
Bare steel on my 66 automatic
January 28 1966 Dearborn manufactured hardtop 289 2v 3spd manual
