Author Topic: 67-70 Pop open fuel cap converson  (Read 1792 times)
Offline gimpystoy
« Last Edit: June 08, 2015, 01:26:12 AM by J_Speegle »
67 C code Metuchen, May "67" build 289 C4
Re: Pop open fuel cap converson
« Reply #1 on: May 05, 2015, 06:32:58 PM »
Although it is a Ford part, it is not factory correct.  I think this was the result of trying to put a small Band-Aid on the concerns about rear mounted gas tanks.
I've also seen Ford service pop open gas cap shell with the twist off cap hidden below, listed as NOS.  I think that description is a bit of a stretch myself.
« Last Edit: May 05, 2015, 08:47:06 PM by 67gta289 »
Offline gimpystoy
« Reply #2 on: May 05, 2015, 07:32:32 PM »
Kinda what I thought.
Offline WT8095
  • Dave Z.
« Reply #3 on: May 05, 2015, 09:27:10 PM »
Technically it is NOS -unused, 20+ years old. And it's an extreme example of the mantra that's repeated here so often, that an official Ford service part does not necessarily equal what was used on the production line!
[maybe NOS stands for Not Original Stuff?  ;)]
Dave Z.
Offline gimpystoy
« Reply #4 on: May 06, 2015, 12:08:19 PM »
The difference between those who know a little vs the REAL info. available" here"
« Reply #5 on: May 06, 2015, 12:51:27 PM »
The basic "need" for this, as John stated above is that the 67-up center mounted POP-OPEN gas caps would do just that in a rear-end collision, they would pop-open, often dumping large amounts of gasoline out. Any genius can figure out why this safety-related item would come around for that reason alone...Add all the hype of the Pinto's blowing up back in the day and you have hysteria! NOTICE the engineering number and instructions date the design as 1993.
Sheese, the Crown Victoria was still blowing up well into the new mellinium if hit hard enough but that didn't slow down production of these hazzards much. You never saw a "Relocation Kit" provided by Ford for that tank (mounted behind the rear axle, these cars collapsed on 20MPH collisions even)
This item was intended to calm "fears" is all.
« Last Edit: May 06, 2015, 12:57:58 PM by 67gtasanjose »
