Author Topic: 65 Exhaust Hanger  (Read 1215 times)
Offline 66RavenGTCoupe
65 Exhaust Hanger
« on: May 04, 2015, 07:21:03 AM »
Hi All,
I'm restoring my wive's 65 V8 convertible built Sept 64 at San Jose and I was looking to get a correct replacement part for her pass side single transverse exhaust hanger as the rubber is perishing but no one seems to have one that looks like it. Just wondering....
A) If it is the correct part to start off with?
B) If I can get a new one?
ans
C) If I can get the pins to restore the one I have?
Any Help here would be great.
Regards,
Daniel.
« Last Edit: May 07, 2015, 06:09:18 PM by J_Speegle »
66 Metuchen, NJ  GT Coupe
Raven, Deluxe Black Int
6T07A1612##
BODY  COLOR   TRIM    DATE   DSO   AXLE  TRANS
    65B     A      66           02M     22          1     6
Buck Tag:
C/O  362  (Customer Order, Rotation Number)
5    M7 (Weld Bay 5, Bucked Dec 7)
PIO (Performance Image Option - GT)
Online 67gtasanjose
Re: Correct Single Exhaust Hanger
« Reply #1 on: May 04, 2015, 01:36:23 PM »
I know of where you might get a NOS replacement. Private Message me and I'll tell you where. I had posted it here earlier, but I updated the reply because somebody else might snatch it away before you responded... but I might also consider replacing the rubber only. Scott Fuller was looking into the correct rivets back a few months (January?) and replacement tire sidewall rubber is all you would need. This is assuming the rest of the hanger is good. Just an idea, but even if you replace it, I would hang onto the original one.
« Last Edit: May 04, 2015, 01:58:36 PM by 67gtasanjose »
Online outlawincorporated
  • Kangaroo Herder
« Reply #2 on: May 05, 2015, 08:41:23 AM »
Daniel.
someone in your own backyard might have the part you require.  C5ZZ-5A246N.
Regards.
PHILL BERESFORD.
MELBOURNE.
AUSTRALIA.
Offline wunderwerks
Re: 65 Exhaust Hanger
« Reply #3 on: May 19, 2015, 08:34:31 PM »
Are the reproductions not even close to the originals?  What are good used or even NOS one going for?
64.5 Cpe. Poppy Red 5F07D 23G
64.5 Conv. Bright Cherry Sparkle 5F08F 16F
65 2 + 2 Caspian Blue 5F09K  23K
