Author Topic: Oil Pressure Sending Unit  (Read 2645 times)
Offline wjgrnp
« on: May 04, 2015, 01:19:07 AM »
Hi
My oil pressure gauge has suddenly stopped working.
Thought I would start the repair process with a replacement Sending Unit.
At the moment I have a standard looking Bell Shaped unit as part of the filter housing.
Not too many big blocks here in Australia however easy to purchase small block Cleveland parts.
Guidance on interchange or a part number for the 428 would be appreciated.
Ward
70 Mach 1 428 CJ with AC and C6
3.25 with Truetrac limited slip
Metuchen
December 30 1969
Yellow
Re: Oil Pressure Sending Unit
« Reply #1 on: May 04, 2015, 03:40:54 AM »
We'll need to know if you have a tach dsh to know if you have a oil pressure gauge or "idiot light""
Offline GT500KR
  • Charlie Ping
« Reply #2 on: May 04, 2015, 10:29:57 AM »
Since you refer to it as a Gauge, and describe the sending unit as bell shaped, it sounds like you are describing the part in the picture below. I believe that they are the same from 1965 to 1985 in Ford cars and trucks that use a gauge.
A simple test would be to have an assistant sit in the car with the ignition switch on, watching the gauge, while you provide a ground to the lead that attaches to the sending unit (Just a few seconds is enough). If the gauge needle moves, the sending unit is likely bad. If nothing happens, the problem is in the gauge, or the wiring to it.
« Last Edit: May 04, 2015, 10:35:46 AM by GT500KR »
Current Project:
64.5 Black DB Cpe
5F07D1131XX  4/14/64
The stable:
65 Ivy Green Coupe 4SPD
68 Candy Apple Red GT500KR 4SPD FB
70 Grabber Blue Boss 429
86 JalapeƱo Red GT  5SPD
91 Emerald Green Saleen Conv. 5SPD
03 Sonic Blue Cobra Conv.
07 Black GT500 Cp
« Reply #3 on: May 04, 2015, 06:57:21 PM »
The Dearborn bell shaped oil pressure senders had a makers mark of FOMOCO in block letters in a rectangle (not script or in a oval) . Other plants may have similar.
« Reply #4 on: May 04, 2015, 09:44:56 PM »
Like this?
« Reply #5 on: May 04, 2015, 10:29:21 PM »
I think you have this backwards.  Grounding the sending unit makes the gauge peg high.  That checks the wiring and the gauge itself.  If it pegs high, then the sending unit is at fault.  If it does not peg high, then the gauge and/or the wiring is bad.
« Reply #6 on: May 05, 2015, 03:04:57 AM »
Offline rayms69
« Reply #7 on: May 05, 2015, 05:02:32 PM »
My car doesnt have the gauge, i mistakenly bought an NOS Autolite unit never installed. If you need one, give me a shout. I have lots of 69 parts, that no worky on my 70
« Last Edit: May 05, 2015, 05:05:06 PM by rayms69 »
10-26-1969 Dearborn 428 SCJ auto
Offline wjgrnp
« Reply #8 on: May 11, 2015, 08:39:18 AM »
Thanks for the feedback
Replaced the sender unit and all is back working
Not an easy fix with AC and PS.
Thank you
Ward
Metuchen
December 30 1969
Yellow
