Author Topic: 1968 bellhousing color ?  (Read 1169 times)
Offline mhubert89
« on: May 03, 2015, 02:57:34 PM »
hi,
if i want to put back my bellhousing like original, wich color will be the closest for my 289 4 speed for dearborn...alumiblast, cast blast ?
thanks
Mustang Fastback 1968
289, 4 speed
Re: 1968 bellhousing color ?
« Reply #1 on: May 03, 2015, 03:09:32 PM »
It was natural cast aluminum originally.
Offline mhubert89
« Reply #2 on: May 03, 2015, 03:30:23 PM »
oki , thanks !
289, 4 speed
« Reply #3 on: May 03, 2015, 04:00:47 PM »
Your posts indicate a paint finish. Don't paint it! Scrape the big chunks the housing off first, scrub it down with solvent (paint thinner) or a mild degreaser (I don't know what Evapo-Rust does) rinsing with dish soap in between steps. Don't use oven cleaner, it has an acid base and will leave an ugly white surface, in fact avoid anything with acid in it. A mild scrub brush works, steel wool or a wire brush will wreck the surface. You might try Simple Green (it has an odor that makes me sick so I don't use it) or Krud Kutter available at Home Depot in the paint department. I don't know what's available in Canada (make a run to New York if you have to).
« Reply #4 on: May 03, 2015, 09:10:39 PM »
Once cleaned like Jim described, I have heard having it "tumblered" can bring back some of it's original finish. It uses a different media than steel parts though. A big tumbler is needed.
