Author Topic: Finish on E brake and front disc brake hose retaining clip  (Read 1819 times)
Looking for concensus on the finish of E brake hair pin clip retaining the E brake cables to back of car and front disc brake hose retaining clip holding the hose fitting into the frame rail bracket. zinc phosphate or safety red . Let me hear some input.
Re: Finish on E brake and front disc brake hose retaining clip
« Reply #1 on: April 21, 2015, 10:39:04 PM »
What year?  ;)  Think it might make the difference
« Reply #2 on: April 21, 2015, 10:44:05 PM »
As the heading indicates 1964 1/2 -1966 . I thought listing the years would be redundant considering the heading it is under.
« Reply #3 on: April 21, 2015, 10:48:04 PM »
Opps 6 tabs open at the same time with different topics :(
Will check and post
« Reply #4 on: April 21, 2015, 10:58:52 PM »
Will check and post
Been there ,done that Jeff. All opinions welcome and appreciated.
Online CharlesTurner
« Reply #5 on: April 21, 2015, 11:28:10 PM »
Posted on SAAC forum too... most of these I have seen on 65-66 were phosphate or darkened steel appearance.
« Reply #6 on: April 22, 2015, 12:28:16 AM »
Those clips were stamped from spring steel stock which has a slight gloss from the original steel manufacturing process. The texture should not be the flat finish you get from phosphate. The raw stock was on a roll but it tended to get scratched from handling. Gun black probably is the closest for touchups.
« Reply #7 on: April 22, 2015, 12:48:39 AM »
Thanks guys.
« Reply #8 on: April 22, 2015, 02:45:43 PM »
Didn't find any evidence of the safety red on original 65-66 applications (parts that your referring to) Though later and NOS examples were easy to find
