Author Topic: 289 fan spacer hardware  (Read 1690 times)
Offline mhubert89
« on: April 19, 2015, 11:23:19 PM »
hi,
i am looking for the bolts kit to bolt my fan & my fan spacer to my engine..i have a original 3 inch spacer so i need the bolt kit please !
i have a 289 68
appreciate
Mathieu
Mustang Fastback 1968
289, 4 speed
Re: 289 fan spacer hardware
« Reply #1 on: April 20, 2015, 01:23:11 AM »
Do you just want used originals?
Offline mhubert89
« Reply #2 on: April 20, 2015, 10:50:08 AM »
no but i can't find them for the lenght i need ! only see for spacer like 2.25 '' ! do you know where i can find them ?
289, 4 speed
« Reply #3 on: April 20, 2015, 03:14:40 PM »
Try AMK B-12452 for Ford p/n 379192-S8. It's 5/16-24X3 3/4 with an attached split lock washer. It was used in 1965 for the spacer length you indicated. Taking into account the thickness of the spacer, fan and pulley, it will be long enough. Unfortunately there is no 1968 Engine Assembly Manual to use for determining the factory installed hardware, but using the 67 Manual, the bolt used for the C5OE-8546-A spacer is 45555-S2, 5/16-24X3 5/8 with a split ring lock washer. I don't think the extra 1/8 inch in length of 379192-S8 will matter, but check it for any interference. It can always be cut if too long.
Offline DKutz
« Reply #4 on: April 20, 2015, 03:51:59 PM »
mine are just cut off...
Offline wunderwerks
« Reply #5 on: April 27, 2015, 09:45:29 PM »
I have a set of four originals with lock washers.  Send me a PM if you still need them.
64.5 Cpe. Poppy Red 5F07D 23G
64.5 Conv. Bright Cherry Sparkle 5F08F 16F
65 2 + 2 Caspian Blue 5F09K  23K
