Author Topic: 69 Engine Bay decals & tags  (Read 4773 times)
Offline mwizz
« on: April 19, 2015, 07:58:41 AM »
I have a 69 S Code 390 4V which was built in San Jose on July 15, 1969. Just wondering what decals and tags should show in the engine bay as the previous restoration that had been completed did not include any of these. Any assistance will be appreciated.
Re: 69 Engine Bay decals & tags
« Reply #1 on: April 19, 2015, 05:23:51 PM »
First DON"T BUY A DECAL KIT!  ;)
On lets see if I can get all of them from memory
1- Engine ID sticker - passenger side head front surface
2- Engine timing decal - drivers side valve cover outer surface below the breather
3- Battery inspection decal - black printing on basic sticker. No one sells on filled out commercially
4- Service decal - drivers side shock tower typically to right about inline between the two lower shock/spring cover bolt heads
5- Air cleaner cubic inch decal - top front center or lid
6- Autolite filter service decal - air cleaner base drivers side between dist dimple and vacuum door
Offline mwizz
« Reply #2 on: April 19, 2015, 08:31:24 PM »
Thanks Jeff, are there supposed to be any number tags on the firewall? or were these not on San Jose cars.
« Reply #3 on: April 19, 2015, 08:35:29 PM »
I think your referring to the inspection stickers applied to the cowl and other areas - nope - not typical on 69 San Jose cars. They used other methods - that was Dearborn that used those - and that changed somewhat late 69
Offline mwizz
« Reply #4 on: April 20, 2015, 11:57:44 PM »
Thanks Jeff, appreciated
Offline ninedrvr
« Reply #5 on: June 09, 2017, 05:14:02 PM »
OK. What about a Dearborn 390? Is this list still the same?
Offline ninedrvr
« Reply #6 on: June 09, 2017, 05:15:26 PM »
Offline ninedrvr
« Reply #7 on: June 09, 2017, 05:41:01 PM »
Also, what's the difference between ID tags K385S and K385T? They both show correct for a 1969 390 4V with an automatic transmission.
« Reply #8 on: June 11, 2017, 07:01:01 PM »
Since decals/stickers that were applied at the assembly plants they would differ in how they were filled out or sometimes supplier and often different locations while most if not all (depending on year  & plant) engine decals were applied at the engine assembly plant they would be more alike
Believe it reflects an internal engine variation that changed during the manufacturing year See response #`13
« Last Edit: June 12, 2017, 06:08:03 PM by J_Speegle »
Offline ninedrvr
« Reply #9 on: June 12, 2017, 07:50:49 AM »
Ok. So where have you seen the engine ID tag? I've only seen it on the front of the drivers side valve cover.
« Reply #10 on: June 12, 2017, 02:32:19 PM »
For a 69 390 engine Have a question that may or not have a a bearing on the placement.
With or without the chrome engine accessory option?
Offline ninedrvr
« Reply #11 on: June 12, 2017, 03:53:46 PM »
With the chrome dress up.
« Reply #12 on: June 12, 2017, 05:30:07 PM »
From above
Same engine plant - different FE engine
« Reply #13 on: June 12, 2017, 06:07:23 PM »
According to one source the S = manual trans and the T = automatic trans
Offline ninedrvr
« Reply #14 on: June 13, 2017, 09:27:29 AM »
Thanks Jeff. I just ordered the correct decals.
