Author Topic: 65 Sway Bar  (Read 1440 times)
65 Sway Bar
« on: April 18, 2015, 07:53:32 PM »
     Replacing the aftermarket end links and bushings on the 65 GT 7/8" sway bar.  The after market end link bolts are 6 & 1/4 " long and the install would have been easier if they had been a bit longer.  The Drake sway bar bushings are 2" tall and my bushing bracket is about 1 & 1/2" deep maybe a little less.  Do I just tighten the snot out of the bushing brackets to get them flush to the mounting surface ?  Are my brackets correct ?  Thanks,  Brian
« Last Edit: April 18, 2015, 10:21:59 PM by Brian Conway »
Re: 65 Sway Bar
« Reply #1 on: April 18, 2015, 11:30:41 PM »
The brackets look right.  The bushings will squash a bit when torqued.
Original 65-66 GT sway bar was 13/16"
Re: 65 Sway Bar
« Reply #2 on: April 19, 2015, 12:08:25 PM »
OK they do squash down.  Interesting about the 13/16" sway bar.  My sway bar measurement came out at .835.  Thanks,  Brian
Re: 65 Sway Bar
« Reply #3 on: April 19, 2015, 03:41:28 PM »
The factory end link bolts should be 5 13/16 long. Also, the spacer sleeves are supposed to be 1 1/2 inches long. Aftermarket items are often "problematic".
A used "relaxed" bushing on a GT sway bar I have is 1.870 inch in height. The bar diameter taken in the center was 0.840 inch and 0.850 inch 90 deg away (I use a mechanical dial, the batteries kept wearing out).
Offline michaelvonlanthen
Re: 65 Sway Bar
« Reply #4 on: September 12, 2020, 06:35:31 PM »
I just bought an original 13/16" special handling package / GT sway bar for my 64.5 V8.
1. Can I reuse my sway bar brackets?
2. Scott Drake sells the concours 7/8" bushings and mention that they are correct for a GT / SHP sway bar. Can I go with those or better use a 13/16" repro bracket and urethan bushings-kit ?
Michael
« Last Edit: September 12, 2020, 06:38:56 PM by michaelvonlanthen »
Michael Vonlanthen
Switzerland
5F08D189*** - 76A   F   42   06G    75   1   6
Guardsman Blue Convertible with white interior, AT, PB, AC, console, Rally-Pac
