Author Topic: Clutch Rod Finish  (Read 1621 times)
Offline Redline
Clutch Rod Finish
« on: April 27, 2010, 04:35:24 PM »
What is the correct finish for a 1965 June Dearborn clutch pedal to equalizer bar rod & adjusting nuts? Also what is the correct finish for the clutch equalizer bar frame side bracket mounting hardware?
MCA# 52738
Certified National Judge 1964 1/2-1966 Mustang
Re: Clutch Rod Finish
« Reply #1 on: April 27, 2010, 05:24:00 PM »
Threaded rod would have been a plain steel with oil coating.  Adjustment nuts, clear zinc.
The 2 bolts that attach the pivot bracket to the chassis would have been zinc plated also.  They are a unique bolt with a flared base/shoulder.
