Author Topic: correct clip for engine harness on tower brace - 65 San Jose  (Read 7438 times)
Offline DKutz
« on: April 16, 2015, 01:57:43 PM »
What is the correct clip to use to attach the engine wiring harness on to the passenger side Shock tower brace. I have two plastic lips that I ordered, but they don't seem to stay attached...
« Last Edit: April 17, 2015, 06:40:18 PM by J_Speegle »
Offline Richard P.
Re: correct clip for engine harness on tower brace
« Reply #1 on: April 16, 2015, 04:01:04 PM »
Can you provide more information about the clips that you're trying to install. If they're the ones I'm thinking about they should not be plastic. They maybe rubber coated.
Offline D0ZZ70MACH
  • 1970 Mach 1 Dearborn 11/10/1969
« Reply #2 on: April 16, 2015, 08:15:08 PM »
The 1970 Ford Osborn assembly manual shows Ford P/N 95832-S.  AMK sells them.
http://www.amkproducts.com/bulk5.asp?part=B-13200
Offline D0ZZ70MACH
« Reply #3 on: April 16, 2015, 08:19:06 PM »
or 383477-S for the underside of the shock tower braces also sold by AMK
 http://www.amkproducts.com/bulk7.asp?part=B-13114
« Reply #4 on: April 16, 2015, 11:23:59 PM »
Neither of those were used on a San Jose 65
« Reply #5 on: April 16, 2015, 11:27:39 PM »
Are you asking for your 65 fastback?
If so then the typical metal with the rubber dipped tips/end are what was typically was used
No idea of what they are selling or you received
Offline D0ZZ70MACH
« Reply #6 on: April 16, 2015, 11:33:50 PM »
Guess I need glasses.   Sorry for the bum info!!
« Reply #7 on: April 17, 2015, 01:22:29 AM »
It would help if you tell us what part number you ordered.
Look at AMK B-10723, 2014 Cat pg 144 Ford p/n 372302-S(similar), 372303-S100. The only drawing/picture I've located is in the AMK catalog. They are rubber coated steel (see Jeff's post)
Offline DKutz
« Reply #8 on: April 17, 2015, 12:54:02 PM »
So I THINK it is These that I need.  The platic clips that came witht he kit I bought don't hold very well...
http://www.virginiaclassicmustang.com/65-66-WIRING-CLIPS-FOR-RH-SHOCK-TOWER-BRACE-SET-OF-2-P3854C1210.aspx
« Reply #9 on: April 17, 2015, 02:47:42 PM »
no need to think any further. those are the ones. buy some extras too.
« Reply #10 on: April 17, 2015, 04:48:39 PM »
Those look like the ones used in the trunk but with the rubber coating. Not what I've found on Fall 64 San Jose cars as shown below
Online CharlesTurner
« Reply #11 on: April 17, 2015, 05:28:21 PM »
The small ones were Dearborn/Metuchen style.
« Reply #12 on: April 17, 2015, 06:45:37 PM »
I had questions on this clip for both my SJ 66 Hardtop and SJ 66 K Fastback, they both came with 372047-S100 clips as shown, the K uses an additional clip for the manual choke cable. The clip "may" also retain the convertible power feed cable.
There is one more clip of this type used on the radiator support by the battery replacing the plastic strap, 376914-S, again San Jose only - unless someone with a 64-66 Metuchen or Dearborn Mustang, or 64-65 San Jose Mustang wishes to contribute more information about these variations.
I did find that my 64-66 Hardware Spreadsheets had documented this variation, but I reworded the application for clarification.
« Reply #13 on: April 17, 2015, 07:13:41 PM »
I had questions on this clip for both my SJ 66 Hardtop and SJ 66 K Fastback, they both came with 372047-S100 clips as shown,..............There is one more clip of this type used on the radiator support by the battery replacing the plastic strap, 376914-S, again San Jose only - .........
Yes that clip is used on 66 San Jose (change from 65 production) to keep that wire up and away from the battery. Apparently a fix
Re: correct clip for engine harness on tower brace - 65 San Jose
« Reply #14 on: April 17, 2015, 08:38:48 PM »
Yup, just like you, Rich and Bruce showed us 20 years ago. Just verifying San Jose only.
