Author Topic: Cleaning carbon off 69 shelby exhaust collector and plenum  (Read 1473 times)
Offline Bob Zink
Does anyone know a good way to remove the carbon and make the collector look new again?  Also, the long aluminum plenum that goes behind the valence has a ton of carbon built up.  I would like to clean that too while it is off the car if anyone can share a good way to do it.  Thanks.
Re: Cleaning carbon off 69 shelby exhaust collector and plenum
« Reply #1 on: April 15, 2015, 03:29:24 AM »
Depending on how built up the carbon is you can use eagle wire wheel or eagle aluminum wash and a stiff plastic brush. Of course wash it off with the hose.  Otherwise beadblast then use the cleaner and brush for a more original look.FYI the inside of the exhaust port is painted black.
« Last Edit: April 15, 2015, 11:59:45 AM by Bob Gaines »
Offline WT8095
  • Dave Z.
« Reply #2 on: April 15, 2015, 01:39:38 PM »
I've used soda blasting to remove carbon deposits from aluminum cylinder heads. It's even less aggressive on the metal than bead blasting. It will take the ink off a pop can without warping it. Not the most cost-effective way to recycle aluminum cans...  :D
Dave Z.
« Reply #3 on: April 16, 2015, 11:30:21 PM »
Have used walnut shells - not easy to get though everywhere.
