Author Topic: Finish of AC idler pulley brackets  (Read 1998 times)
Offline wunderwerks
« on: April 11, 2015, 10:11:52 PM »
I'm replacing the bearings on both the fixed and adjustable idlers pulleys on my 66.  While I have them apart I want to refinish them back to factory original.  I believe the pulleys were painted semi-gloss black but I thought the brackets were natural.  I haven/t been able to verify this anywhere thus far.  I have an NOS adjustable bracket on ebay right now for a full size Ford and the entire bracket and pulley appear to be finished in a charcoal phosphate.  Can anyone point me in a direction of where I can find the correct finish for these pulleys?
64.5 Cpe. Poppy Red 5F07D 23G
64.5 Conv. Bright Cherry Sparkle 5F08F 16F
65 2 + 2 Caspian Blue 5F09K  23K
Re: Finish of AC idler pulley brackets
« Reply #1 on: April 11, 2015, 11:11:09 PM »
Yes, seen that on 65-66, natural/phosphate bracket with black painted pulley and zinc plated bearing cap/natural bearing end.
Offline ChrisV289
« Reply #2 on: February 02, 2016, 03:13:31 PM »
Sorry to bring this up just wanted to be sure early cars (October 64) were this finish and not all black. Rules state either way but would like to be correct
2009 V6 Mustang Coupe
Offline ChrisV289
« Reply #3 on: February 05, 2016, 08:03:25 PM »
Is this about the correct finish on this bracket? I stripped the black paint off of it (most so far) and this is what was underneath? If correct how do I go about protecting it?
Offline mgmradio
« Reply #4 on: February 05, 2016, 11:51:56 PM »
That's what it should look like.
« Reply #5 on: February 06, 2016, 12:20:38 AM »
As mentioned before ,the bracket is bare cast iron,pulley is between semigloss and glossier blackand center cap is zinc silver. The preferred method of protection for the cast steel is T9 or similar rust inhibitor rather then clear coat.FYI it will protect the plating also.
« Reply #6 on: February 06, 2016, 05:41:43 PM »
As mentioned before ,the bracket is bare cast iron,pulley is between semigloss and glossier black and center cap is zinc silver. ..............
:)  - Late 66 Non Thermactor AC 289 original example - This car http://www.concoursmustang.com/forum/index.php?topic=5371.msg30157#msg30157
« Last Edit: February 06, 2016, 05:56:31 PM by J_Speegle »
