Author Topic: 70 NJ Boss 302 - gold wittek smog system clamps  (Read 3108 times)
Offline kcodecoupe
« on: April 10, 2015, 07:48:35 AM »
How many gold wittek clamps were used on a 70 jan built metuchen boss 302 and the location on the  smog  system, thanks.
« Last Edit: April 28, 2020, 08:51:04 PM by J_Speegle »
Re: gold wittek smog system clamps
« Reply #1 on: April 10, 2015, 11:26:02 PM »
If we're just counting thermactor related ones (not ones used elsewhere in the engine compartment) think you only need two  of the clamps. Both on the long hose from rear of the intake (check valve) to the gulp valve
Offline rockhouse66
« Reply #2 on: April 11, 2015, 08:46:36 AM »
Jeff - so you think the hose from diverter to smog pump uses a tower clamp both ends?  I was thinking just on the top at the pump?
'66 GT FB
« Reply #3 on: April 11, 2015, 05:57:33 PM »
Jeff - so you think the hose from diverter to smog pump uses a tower clamp both ends? .........
Yes at this point- But can't be sure and can't find a picture that will show that detail on an original car. Drawings of the system seem to suggest tower both ends but would welcome (as always) input from original cars :)
« Reply #4 on: April 14, 2015, 03:26:29 AM »
Just posted a picture over on the Boss 302 site - so figured it needed to be here also ;)
Unrestored - low mileage example 0F02G190xxx
Offline kcodecoupe
« Reply #5 on: April 14, 2015, 09:30:02 AM »
Thank you for posting the picture jeff, is the band clamp on the outlet port of the diverter valve in the picture gold cad or silver cad .
« Reply #6 on: April 22, 2015, 05:10:00 PM »
Sorry taking so long getting back to this one
For the band (heater hose style) clamp believe originally the clamp was galvanized with the nut and bolt being silver cad. The Witteck (S?) was either gold cad or zinc dichromate. Have never tested either to know for sure but that should give you the look
Offline 79mustangcobra
« Reply #7 on: April 23, 2015, 02:35:04 PM »
1979 Mustang Cobra 5.0
2P Red and 1C Black
Stock never goes out of style
MCA #70281 -  79-93 MCA Concours Judge
Proverbs 3:5-6
