Author Topic: 289 2V Crankshaft pulley  (Read 2115 times)
Offline Building 3
« on: April 09, 2015, 07:01:10 PM »
Is the crankshaft pulley for the December 1965 built 289 2V with PS, no A/C, no emissions, a C5 or C6 part number? Thanks.
« Last Edit: April 10, 2015, 11:07:08 AM by Building 3 »
Offline suskeenwiske
  • 214-347-3628
Re: 289 2V Crankshaft pulley
« Reply #1 on: April 09, 2015, 07:24:10 PM »
My April 28 '65 Dearborn Crankshaft Pulley # starts with C5.
Ray
Ray
1965 Dearborn Coupe
6 Cylinder, AT, PB, PS, AC
Est. Build 23A
« Reply #2 on: April 10, 2015, 01:16:42 AM »
Is the crankshaft pulley for the December 1965 built 289 2V a C5 or C6 part number? Thanks.
Without power steering, air conditioning or smog equipment the pulley would be a single grove and may, or not, be marked "C5AE-A" per Mannel Appendix B page B-9. The "or not" I found to be strange but that's what is stated in the notes. Same single grove for 65 thru 67.
Offline GT500KR
  • Charlie Ping
« Reply #3 on: April 10, 2015, 10:30:52 AM »
+1 All the examples I have seen have been marked C5.
Current Project:
64.5 Black DB Cpe
5F07D1131XX  4/14/64
The stable:
65 Ivy Green Coupe 4SPD
68 Candy Apple Red GT500KR 4SPD FB
70 Grabber Blue Boss 429
86 Jalapeño Red GT  5SPD
91 Emerald Green Saleen Conv. 5SPD
03 Sonic Blue Cobra Conv.
07 Black GT500 Cp
Offline Richard P.
« Reply #4 on: April 10, 2015, 08:44:51 PM »
+ 1 here
Offline wunderwerks
« Reply #5 on: April 11, 2015, 09:45:38 PM »
All that I've had over the years were all stamped but I just took three off at a salvage yard and one was not stamped anywhere.  I glass beaded it thinking that I just couldn't see it but there was nothing stamped.  It was physically identical to the other two that were stamped.
64.5 Cpe. Poppy Red 5F07D 23G
64.5 Conv. Bright Cherry Sparkle 5F08F 16F
65 2 + 2 Caspian Blue 5F09K  23K
« Reply #6 on: April 12, 2015, 04:03:00 PM »
Different suppliers - sometimes (kind of unusual) you can still find some (across the years) that you can still make out the ink stamping of the ID number on
Offline Building 3
« Reply #7 on: April 13, 2015, 10:28:01 AM »
Looks like I need to find a C5.Thanks for the input.
Offline GT500KR
  • Charlie Ping
« Reply #8 on: April 13, 2015, 10:37:32 AM »
According to Jeff's post, some suppliers used an ink stamp, which is probably long gone on your pulley. If you feel strongly that it is original to your car, I would suggest using it. You may find some cars close to your build date at shows, and compare. C5 pulleys are still pretty easy to find, so you could always grab one and hang on to it though.
Current Project:
64.5 Black DB Cpe
5F07D1131XX  4/14/64
The stable:
07 Black GT500 Cp
