Author Topic: Hood Hinge Body Nuts  (Read 2397 times)
Offline Vcode
« on: March 30, 2015, 09:09:01 PM »
Are the hood hinge body nuts to be tight?
Mine move just a little bit.
Dale.
Re: Hood Hinge Body Nuts
« Reply #1 on: March 30, 2015, 10:52:21 PM »
Guessing that your car is disassembled (hinges off)
If there is not too much play you'll likely get by ok. Problem is that if you tighten and untighten them a couple of times the amount will increase and will lead to them failing. You can tighten them up a little by rebending the metal around them eliminating the play
« Reply #2 on: March 31, 2015, 12:20:51 AM »
Dale.
Worst (or best) possible case is to tack weld from the outside and cover with sealer.
Offline Vcode
« Reply #3 on: March 31, 2015, 04:48:49 PM »
Thanks guys.
I was pretty sure they were to be tight and just wanted to check.
I will see what I can do about bending the metal to tighten them up.
If that doesn't work may add a tack to keep them from moving and be safe..
One more question - what should the finish be for the hood hinges,hood latch and the upper shock brackets on a 1969 May built Metuchen car?
Is phosphate correct?
Dale
« Reply #4 on: April 01, 2015, 12:38:05 AM »
So far, all the 69 hinges, latch and shock brackets I've done for people were a light shade phosphate, I do the springs darker.
« Reply #5 on: April 01, 2015, 01:05:02 AM »
Offline Vcode
« Reply #6 on: April 01, 2015, 10:59:04 AM »
Thanks for the info on the finish.
Dale.
Offline ddonzella
« Reply #7 on: April 01, 2015, 11:07:58 AM »
Hi, Newbie here. What color is Phosphate? Where do  I get that? Is that the same color for a June 12th Dearborn Shelby?
Thank you!
« Reply #8 on: April 01, 2015, 11:13:12 AM »
look in the library section here. lots of info already posted.
