Author Topic: Heater hose routing  (Read 11218 times)
Offline MattDoscher
Re: Heater hose routing
« Reply #15 on: August 15, 2016, 12:33:55 PM »
Yeah they are routed wrong.  There's nothing wrong w/ having the steel tubing there btwn the fan and spacer as long as it's functioning properly.  Since you have to disconnect the hoses you might as well check the condition of the heater core.  It's not too labor intensive.
Matt
Matt Doscher
5H25T582252
Offline Josep
« Reply #16 on: August 15, 2016, 03:17:26 PM »
Googled for the strap and found 2 places that advertise it.
One is CJPony Parts and another one is California Pony Cars. They both look the same.
They don't look like the one shown by you Jeff, so not sure they are correct.
If people did it from old tires, which size/width are they supposed to be..? And, if done, would be concours correct?
Josep
Offline Josep
« Reply #17 on: August 15, 2016, 03:21:19 PM »
Matt
Ok, but even that, the tubing is not connected to the right place, it has to be connected to the upper side of the water pump, now is on the lower side. Yes, have to re-arrange all that stuff and check the core as you suggest, Thanks.
Josep
Offline MattDoscher
« Reply #18 on: August 15, 2016, 09:43:53 PM »
AMK Products has some straps that would work on page 175.  Though advertised as a/c and p/s hose straps it's the same principle.
https://www.amkproducts.com/Catalog_PDF/165-176.pdf
Matt
Matt Doscher
5H25T582252
« Reply #19 on: August 15, 2016, 10:18:35 PM »
Matt
Matt those will work but they won't IMHO look close to what was originally used for either the PS 67-8 application or the 65-66 application. The pictures look to be what we see wrapped around the whole export brace or separate shock tower supports on some 68-70 rather than the hang down straps
Better than nothing?  Yes
Don't know if I've seen one of these in person nor how close they are but here is a possibility (I have no connection with the party selling the part)
http://www.ebay.com/itm/1965-1967-Mustang-Heater-Hose-Retainer-Strap-with-hardware-/152176375642?hash=item236e6b375a:g:lnAAAOSwTZ1XksdU&vxp=mtr
California Pony Cars is listed on the label
« Last Edit: August 15, 2016, 11:04:05 PM by J_Speegle »
Offline Josep
« Reply #20 on: August 16, 2016, 03:33:05 AM »
Thank info MattDoscher,
Jeff, Yes, this is what I have seen and posted before.
Any possibility to know the length and width of the stripe..? Could be 1' long by 1" width.!
Maybe I can try to do one by myself..!
Josep
PS: well, I have done one by myself and just wanted to have your opinion.! Thanks.
« Last Edit: August 16, 2016, 10:21:47 AM by Josep »
