Author Topic: Heater hose routing  (Read 11216 times)
Offline 1966sprint
Heater hose routing
« on: March 29, 2015, 07:18:11 PM »
I am redoing the under hood area on my 1966 Sprint with air.  I have replaced the heater hoses and looking for a picture with the proper routing for the hoses.
Offline NEFaurora
Re: Heater hose routing
« Reply #1 on: March 31, 2015, 02:54:54 AM »
Here is the pic below of the correct hose routing that you need (Top Pic routing), but if your Sprint 200 has "Original" Ford Factory air, It DOES NOT get two Black hoses with White Stripes,  ***Very Important,  If the car had Factory air, It got either Two Black hoses, Both with Yellow Stripes, or One hose was Black with a Yellow Stripe (nearest to the A/C Compressor), and the other hose was Black with a White Stripe (Furthest away from the A/C Compressor).
But even more important, Is your 1966 Sprint 200 in the Sprint 200 Registry??
If not, Send me an e-mail at: NEFaurora@aol.com as I run the registry.
:o)
Tony K.
« Last Edit: March 31, 2015, 03:04:38 AM by NEFaurora »
MCA#70001
Offline 1966sprint
« Reply #2 on: March 31, 2015, 09:40:42 AM »
Thanks Tony,
Would you have a photo of the hoses from the firewall to the carburetor?  I cant seem to get them through the strap where they look right.
I will get the car info to you for the registry.
Offline NEFaurora
« Reply #3 on: March 31, 2015, 12:58:00 PM »
Tom, I sent you an e-mail..
:o)
Tony K.
MCA#70001
« Reply #4 on: April 01, 2015, 07:09:27 PM »
You didn't include where the car was built nor during what period of time.
Couple of examples
Late 66 Dearborn
San Jose with rubber holder. Depending on worker, time period and/or additional options the strap was attached with one or two screws
Offline NEFaurora
« Reply #5 on: April 01, 2015, 10:33:41 PM »
Jeff, He's got a Dearborn built 1966 Sprint 200 with an "07G" Date code.  He also has the dual straps on the passenger side just like your Dearborn top picture.
He had a concern though.  Out of the two straps on the Passenger side He would like to know what hoses route through what straps......Both hoses through both straps, or top hose through forward strap, and bottom hose through rear strap?  or something different???
:o)
Tony K.
MCA#70001
« Reply #6 on: April 01, 2015, 11:15:10 PM »
Thanks - knowing that at the beginning would have cut the search by 50%
What I've got
On 6F07T1272xx (non-AC car) both hoses are routed through (one on top of the other) the passenger side rubber strap. At least one hose has been replaced
On 6FT07T2480xx The AC thin line is attached to the drivers side shock tower. While the passenger side rubber strap holds both heater hoses up. Heater hoses have been replaced on that car. No sign of a second metal strap on the passenger side
On 6F07T3622xx ( the prior top picture)
With the AC the front strap holds only one heater hose, the  hose and the metal rear one holds the thicker AC line. The heater hose from the carb spacer goes back, up and over  the AC line - so it and the metal strap hold that heater hose up and out of the way on that original car.
On 6F08T7219xx There are three straps like the above example. One on drivers side for the thin AC line. One metal and one rubber on the passenger side. Unfortunately the view is obscured so can provide anything else :(
Offline NEFaurora
« Reply #7 on: April 02, 2015, 10:53:06 AM »
Much Thanks for your help Jeff.
:o)
Tony K.
MCA#70001
Offline 1966sprint
« Reply #8 on: April 08, 2015, 11:31:06 PM »
Tony and Jeff, I appreciate the assistance.  With the holiday I have been away from the forum.  Thanks again.
Tom
Offline Josep
« Reply #9 on: August 14, 2016, 04:19:46 PM »
Alright, I know this is a very old post, but since I have to replace the heater hoses, I would be very interested to know the heater hoses routing.
I see from this pic the rubber holder and am interested in knowing what would be for my car the right/correct routing, if it had to have that strap, or had to has clips to attach the hose to block, etc..
I don't see any hole were the clip could be attached in my block, and not sure if any hole in the export brace to hold that strap.. will check in daylight.
Thanks for help,
Josep
« Reply #10 on: August 14, 2016, 05:14:36 PM »
Believe they were built as shown in the unrestored example pictures above
Thanks for help,
Is your car an "export" car with the one piece export brace or with the separate shock tower suuports (2) as shown in the pictures?  This would relate to the rubber hanging strap. If its the typical non-export two piece style then it would have typically had the rubber strap on your application
Offline Josep
« Reply #11 on: August 15, 2016, 05:42:50 AM »
No Jeff, my car was build in SJ and sold in LA, so no export car. Then, I assume it had to has the rubber hanging  strap. Here are some pics.
Passenger side brace and drivers side brace. I note that they have two small holes (in each brace) that I don't know for what they were supposed to be used. And BTW, any chance to get a original strap..? Repro.?
« Last Edit: August 15, 2016, 05:45:40 AM by Josep »
Offline Josep
« Reply #12 on: August 15, 2016, 06:01:30 AM »
Looking at that configuration, I note that my hoses are incorrectly put..!! For some reason, I didn't realize they were put wrong, probably when PO did the restoration..
There's a section going from the lower part of the water pump to carb that is steel tubing, and assume it has to be rubber, but definitely they are swaped.
Josep
« Reply #13 on: August 15, 2016, 06:22:30 AM »
Ford put holes in both braces to accommodate other options, accessories and engine types. On the drivers side the holes were used to hold up AC lines for cars with that option
Someone was making the straps at one point  - not sure now. Before the reproductions owners and shops would just make their own from used tires
Offline Josep
« Reply #14 on: August 15, 2016, 11:13:36 AM »
Good solution.!! Thanks.!!
Josep
