Author Topic: Interesting early '64 1/2 for sale  (Read 8663 times)
Offline mikelj5S230
  • 1964 1/2 K code coupe, 5S230, and 2022 GT500 HE
I don't always downshift, but when I do it is near a Prius so they can hear me hurting the environment.
Offline DKutz
Re: Interesting early '64 1/2 for sale
« Reply #1 on: March 27, 2015, 02:16:21 PM »
nice but if its so low miles and great why did they redo the engine.  I would have perfered patina
« Reply #2 on: March 27, 2015, 02:17:59 PM »
me too...........did you look at the 'fresh' dataplate?
Offline mikelj5S230
« Reply #3 on: March 27, 2015, 03:31:31 PM »
I noticed that, wonder if the original is around.  I always wonder why people do this, but Marti sells such pretty ones, maybe people think it is a good idea to use them????
« Reply #4 on: March 27, 2015, 04:37:56 PM »
A lot of amateur work there, probably should have left it alone.  I do like the patina of the interior though.
The hood should be the first gen style without the front edges turned out, someone probably turned out the edges thinking it was wrong the other way.
Overall it's a neat car, but would require a lot of work to fix the areas restored incorrectly and restore additional areas that should have been done.
Offline Toploader
« Reply #5 on: March 27, 2015, 04:51:13 PM »
"Note proper data code on wheel"... 4L, really?   :o
76A-Y-D2-13H-72-6-6
« Reply #6 on: March 27, 2015, 08:09:22 PM »
Only made 7 months after the car was built   ;)
Offline Richard P.
« Reply #7 on: March 27, 2015, 09:09:21 PM »
I would have thought that the jack handle would be of the open type not rounded. He has the correct spare tire wing nut.
Offline suskeenwiske
  • 214-347-3628
« Reply #8 on: March 27, 2015, 11:35:34 PM »
Carpet is incorrect...wish they were a little closer, I'd go look and bring my camera to take shots of any paint markings. Really only a 4-1/2 hour drive but just don't have the time.
Ray
1965 Dearborn Coupe
6 Cylinder, AT, PB, PS, AC
Est. Build 23A
« Reply #9 on: March 28, 2015, 08:50:13 AM »
look at the front wheels.....behind the hubcaps.......
Offline Dudley
« Reply #10 on: March 28, 2015, 11:05:14 AM »
How does the date code match up with Bob Fria's findings as reported in MM this month? I will look later.
Offline rodster
« Reply #11 on: March 28, 2015, 09:34:30 PM »
What is the 'No reinforcements as in later hoods'  he mentions?   Looks like my 65 hood I think.....
1965 Dearborn Mustang Coupe
Raven Black - Palomino Pony
1967 Dearborn Mustang Conv.
Wimbeldon White - Red
1984 SVO - 2A
Offline Hipo giddyup
« Reply #12 on: March 30, 2015, 10:24:17 AM »
The biggest "issue" I see in the engine compartment is the lower 4 groove pulley with only one belt??? What gives man??   He also speaks of the steering wheel having no cracks but in the second interior pic it clearly looks cracked at the base to me ??  ???  Maybe I'm seeing things?  Alot of little issues but a good looking driver.
Offline Smokey 15
« Reply #13 on: March 30, 2015, 10:35:12 AM »
 If Mustang production started on March 9th, and this car was built on March 25th; how would this qualify as "pre-production"?  Early production. I think this guy is full of it.
« Reply #14 on: March 30, 2015, 11:17:50 AM »
Believe that someone must have changed out the stamped steel pulley's, thinking they were not correct for a 260.  I'm not sure if all 260's had stamped steel pulley's, but most I have seen did.  Not sure why 289's would have cast iron, maybe an engine assembly plant thing.
Yes, agree, they most likely do not understand the early date codes.
