Author Topic: 6 Cylinder Carburetor Spacer Variations  (Read 1351 times)
Offline suskeenwiske
  • 214-347-3628
« on: March 24, 2015, 09:14:15 PM »
I searched through past postings but did not find any reference to what I just found on two Carb Spacers. The hole for the PCV Hose Nipple is 1/4" NPT on one, (bottom photo) and 3/8" on the other. Admittedly, the 1/4" has a 1963 Part Number, C3DE-9A589-F, and the 3/8" a 1966 Part Number, C6DE-9A589-A. Was there possibly a running change made during those three years, or were there actually Spacers that varied depending on the car?
My Engine Block has a December 1964 Date Stamping, the Dearborn Coupe an estimated Build Date of January 23, 1965 and the Carburetor Tag has a first week of February Date Code. My question is twofold: is a Spacer with either a 1964 or 1965 Date Code acceptable and what should the hole size be?
Thanks in advance.
Ray
Ray
1965 Dearborn Coupe
6 Cylinder, AT, PB, PS, AC
Est. Build 23A
Offline C5ZZ
Re: 6 Cylinder Carburetor Spacer Variations
« Reply #1 on: March 25, 2015, 06:07:55 PM »
Ray, Here are a few spacer pictures,
the one on the left is the C3DE version that came off a 65 Fairlane.
The other one is a C6DE (without the gasket) that came off a 66 Falcon.
I would say that you should go with the C3DE version on your 65.
Don't believe I have ever seen a C4DE spacer.
« Last Edit: March 25, 2015, 06:11:32 PM by C5ZZ »
MCA # 00945
Rangoon Red/Red Interior
