Did you have to remove the lower metal dash or loosen it to remove the non/ac 69 heater box? I need to remove mine as well, but have been procrastinating due to having a back problem. I assume the dash pad, the clock bezel, and glove box need removed.
Why are you removing it? To replace the core?
Yes, I need to replace the heater core. I assumed I needed to remove the heater box entirely. This is easy to do on a non A/C compared to one with A/C. I believe that is what the shop manual recommends, but it shows the instructions for an a/c car. Perhaps I don't need to drop the entire box for a non a/c car.
I think it will be easier in the long run to remove the entire box. ..........
Hard to get to some of the clips (tried it) with the back half still attached to the firewall.
West Coast Classic Cougars has a good video on Heater Core replacement, and restoring / refurbishing your heater box:
