Author Topic: 1969/70 Steering Column Question  (Read 2586 times)
Offline sah62
« on: April 22, 2010, 08:59:59 AM »
Does anyone have a 1969 or 1970 column out for easy access to measure something?  I need to know the exact (as in "measured with a caliper, please") diameter of the hole in the bottom of the steering shaft where the mounting flange attaches to the rag joint.  I'm looking to reproduce the foam seals that go inside the lower portion of the column, and while looking at diagrams I found that there's supposed to be a foam rubber plug that fills that opening.  If I know the diameter I can have that plug produced very easily.
Scott Hollenbeck
2019 Lincoln MKZ 3.0T AWD
2003 Mercury Marauder 300A
(more non-Ford stuff)
Offline Aussiemach
  • Silver Level Subscriber
Re: 1969/70 Steering Column Question
« Reply #1 on: April 23, 2010, 10:28:57 AM »
Scott I can measure mine as it's out and will be for awhile yet!!
There are two tubes inner and outer, the inner has a plastic insert in the end. Do you want the inside diameter of the inner tube or the inside diameter of the plastic insert?
1969 Mach 1 351w FMX Built in San Jose, February 26 1969
Offline sah62
« Reply #2 on: April 23, 2010, 03:43:39 PM »
It's best to show you with a picture.  I'm looking for the diameter of the hole that's circled in red where the part numbered 3B361 is installed.
Scott Hollenbeck
Offline Aussiemach
« Reply #3 on: April 26, 2010, 10:31:41 AM »
The inside diameter on mine is 0.79 inches. there is a small amount of surface rust inside but would only amount to a couple of thou.
regards, Andrew
Offline sah62
« Reply #4 on: April 26, 2010, 10:33:50 AM »
regards, Andrew
Thanks - which year column did you measure?
Scott Hollenbeck
Offline Aussiemach
« Reply #5 on: April 26, 2010, 12:46:48 PM »
1969
