Author Topic: 1966 gt steering wheel  (Read 4283 times)
Offline Hipo giddyup
« on: March 22, 2015, 10:50:39 AM »
Can anyone explain the differences between the 66' Fairlane gt steering wheel vs the Mustang deluxe wheel? I have been thinking about purchasing a good used wheel but i am unsure if there are differences? Also, what other items, center, hardware,etc. would i need to convert from the standard wheel? Thanks!
Offline NEFaurora
Re: 1966 gt steering wheel
« Reply #1 on: March 22, 2015, 12:18:16 PM »
As far as I know... The only difference is the emblem in the center cap.  The '66 Fairlane GT has a different emblem.  Other than that, They should be the same wheel..
I don't think that there is any shaft difference between the two..
:o)
Tony K.
MCA#70001
« Reply #2 on: March 22, 2015, 05:01:32 PM »
Just as a small correction. The fake wood steering wheel has nothing to do with the GT package. ;)
Didn't want others to read this and get the wrong idea. Next someone will be referring to the styled steel wheels as GT wheels  ::)
« Reply #3 on: March 22, 2015, 05:46:53 PM »
Thanks Jeff, referring to the deluxe wheel.. So no noticeable differences?? Even part number?? Shaft size is the same as well?
« Reply #4 on: March 22, 2015, 06:38:23 PM »
I don't recall any difference between the two other than the center cap as mentioned. Now 67 is another thing ;)
Offline rocket289k
« Reply #5 on: March 22, 2015, 09:23:59 PM »
+1 for the '65 and '66 Deluxe Steering Wheel ('67 and beyond is indeed a different story)
« Reply #6 on: March 23, 2015, 02:06:11 PM »
Thanks rocket289k for your input. Good to know..
Does anyone know a good source for deluxe steering wheel restoration??? Most of the wheels I find are broken/cracked and missing pieces of the wheel itself.
« Reply #7 on: March 23, 2015, 04:00:10 PM »
A quick search on Yahoo (I don't use Google) found a couple dozen businesses that restore steering wheels. Do some research on a couple and let us know.
Offline rocket289k
« Reply #8 on: March 23, 2015, 06:33:39 PM »
In the event that you decide not to go the restoration route there is only one reproduction that does a good job (texture to the brushed aluminum spokes is subtle like the original part and correct number of silver "dots" (18) on the wheel.  This wheel is a little bit thinner than the OEM part but is otherwise a decent reproduction.  NDP sells this Dlx Steering Wheel as a standalone part only (no trim or other hardware).  NDP part #3600-5A
PS - A dead give-away for the other reproduction deluxe steering wheels is that they only have 17 silver dots on the wheel and the brush marks on the aluminum spokes are way too pronounced.  They also are normally sold as a kit (horn ring, center cap etc. being included).
Regards,
Ron
« Reply #9 on: March 24, 2015, 09:19:05 AM »
Thanks Ron. It seems that almost all of the originals are missing a piece of the steering wheel rim. I was thinking of buying a decent wheel to begin with, probably missing a piece of the rim, and then using a piece from a donor wheel to fill the void. Would show the cracks on both ends of the repair but at least it would be FoMoCo!.  ;D
« Reply #10 on: March 24, 2015, 10:23:26 AM »
They're not really 'missing a piece', the plastic shrinks over time due to conditions... heat/cold/humidity, etc...
I've found that it's best to start with a wheel that has minimal to no cracks for restoration.  The steering wheels with large gaps usually crack again after a while.  Also, consider that the wheels with big gaps will have the chrome dot locations shifted and not spaced out equally.  Looks bad to those that notice and a sign of poor workmanship.  Only way to correct that would be to fill some of the dot holes and re-drill.
