Author Topic: What is thses 2 brackets ?  (Read 1444 times)
Offline mhubert89
« on: March 20, 2015, 07:54:04 PM »
just done the body work on my 68 fastback and put back my rear suspension parts..BUT left me this 2 brackets ! Original or someone put them for something ?
Mustang Fastback 1968
289, 4 speed
Re: What is thses 2 brackets ?
« Reply #1 on: March 20, 2015, 07:58:09 PM »
After market traction bars - similar to the traction master as used on 66 Shelbys though the materials are different.
Leave them off for concours ;)
Offline mhubert89
« Reply #2 on: March 20, 2015, 08:23:51 PM »
for sure they gonna stay right there, on the floor !! thanks
289, 4 speed
« Reply #3 on: March 20, 2015, 08:32:59 PM »
SO they welded the front brackets to the frame like Shelby's - ouch
Offline mhubert89
« Reply #4 on: March 20, 2015, 08:40:50 PM »
if i remember when i remove them, they weres bolt with the rear shocks mounting plate , like if someone use them for hook !
289, 4 speed
« Reply #5 on: March 20, 2015, 11:47:30 PM »
I think Jeff was referring to the front half of the traction bar that is typically welded to the frame rail. It makes for a good amount of work to take it off and make look like it was never there. The ones on the floor are in fact bolted under the spring plate.
1967 eight barrel
  • Guest
« Reply #6 on: March 21, 2015, 12:13:28 AM »
They are TMC ( The original supplier for Shelby) traction master spring plate brackets.. However, this style replaced the original version about 1980. The original is cast and only has provision for three Ubolt holes instead of four, like the ones you have here.
        -Keith
