Author Topic: AC Compressor Bracket  (Read 2828 times)
Offline Munderw
« on: March 19, 2015, 06:43:54 PM »
I need a compressor bracket for my 64.5 mustang 260 with ps and generator.  I believe the correct fit is part # c4za-2882-b.  I can't find that one but do see a fairlane/falcon 3coe-2882-b for sale.  Wondering if the compressor will line up properly and clear the hood with the 3coe bracket.  Thanks in advance for enlightening me.
Mike
64.5 F code
Automatic
5F08F101908
Body 76A
Color M
Trim 89
Date 18C
DSO 75
Axle 1
Trans 6
Offline suskeenwiske
  • 214-347-3628
Re: AC Compressor Bracket
« Reply #1 on: March 21, 2015, 02:50:49 PM »
I don't have an answer but am looking into it. The C4 Part Number, per the Master Parts Catalog, is correct for your application but nothing to show that the C3 will interchange. I'll let you know either way what, if anything, I find.
Ray
Ray
1965 Dearborn Coupe
6 Cylinder, AT, PB, PS, AC
Est. Build 23A
Offline Munderw
« Reply #2 on: March 22, 2015, 01:19:06 PM »
Thank you Ray!
Mike
64.5 F code
Automatic
5F08F101908
Body 76A
Color M
Trim 89
Date 18C
DSO 75
Axle 1
Trans 6
Offline WT8095
  • Dave Z.
« Reply #3 on: March 22, 2015, 02:41:23 PM »
The Ford Master Cross Reference List from April, 1964 lists many entries for basic 2882. The only ones relevant to your question appear to be:
Known P/N        Parts & Acc or Eng P/N
C3AZ-2882-A     C3OE-2882-B
C3OE-2882-B     C3AZ-2882-A
C4ZA-2882-B     C5ZZ-2882-A
C5ZZ-2882-A     C4ZA-2882-B
Note how the listings are "paired", because you can search for either p/n in the "known" column.
So, it's not looking good for the C3OE-B (at least per Ford engineering), but it gives you the C5ZZ-A as an alternative to look for.
Dave Z.
Offline Chris
« Reply #4 on: March 23, 2015, 12:37:10 AM »
The c4za-2882-b bracket is the correct one. It is made to work with the unique power steering bracket for 64 1/2 mustangs when they have both air and power steering. Before I found the correct bracket, I tried the 63 bracket and it doesn't work with the ps bracket. The correct ps and ac brackets share parts for mounting to the engine. There are posts on this from prior discussions.
Offline Munderw
« Reply #5 on: April 16, 2015, 01:39:12 AM »
Thanks everyone.  I got lucky and found the c4za-2882-b part.  I appreciate all the help and guidance.
Mike
64.5 F code
Automatic
5F08F101908
Body 76A
Color M
Trim 89
Date 18C
DSO 75
Axle 1
Trans 6
