Author Topic: Windshield washer pump pedal  (Read 1605 times)
Offline Sunlitgold68
« on: April 20, 2010, 08:32:20 AM »
Does the windshield washer pump pedal come apart? Tried to remove the plastic hexagon part and rubber part but was afraid it may break. If so, how does it come apart, was going to blast and repaint.
8T01C204XXX
Built May 14th, 1968
Re: Windshield washer pump pedal
« Reply #1 on: April 20, 2010, 09:42:00 AM »
I'd recommend masking off the areas that aren't painted before you blast/strip.  I never tried to get one apart.
Offline TLea
« Reply #2 on: April 20, 2010, 09:15:18 PM »
The hex part just screws off
Offline Oz390
« Reply #3 on: April 21, 2010, 11:15:00 PM »
Yep, Tim's on the money.  Plastic and rubber bulb unsrew, can be quite stuck together.  The switch can be pried open and cleaned/lubed.
You "can" drill out the rivet, disassemble, and make a new one, but as noted I just masked and painted.  You can mask the switch box and do a silver/grey and balck eslewher to get "close".  To remove and replate would be a PITA...
I think the rubber bellows is now reproduced, not sure about anything else.
8R03S : 76A I 2A 15M 72 5 U
