Author Topic: C4ZB-17A553-C Switch  (Read 3192 times)
« on: March 11, 2015, 07:15:06 PM »
OE windshield washer switch and pump.  I put this same set up on my 65 GT.  You will need the Black w/White pump wire from the switch, see cut off remnant still in the switch, out to the pump.  Swap for most anything 69 or you can come by and pick it up.  Brian
Offline NEFaurora
Re: C4ZB-17A553-C Switch
« Reply #1 on: December 10, 2016, 10:46:44 AM »
Brian, You forgot to mention whether it was for Single Speed or Dual Speed Wipers...
:o)
Tony K.
MCA#70001
« Reply #2 on: December 10, 2016, 01:37:33 PM »
 :o )
Tony K.
It is a single speed, based upon the 3 pin molded connector that goes to the wiper motor.  The two speed version has a 4 pin square molded connector.
