Author Topic: Down draft tube grommet - valve cover  (Read 1342 times)
Offline russgoodman
« on: March 07, 2015, 04:57:22 PM »
13-14 years ago when I was initially cleaning up the engine compartment, I removed the valve covers for a strip and repaint. I carefully tried to remove the down draft tube grommet from the passenger side valve cover and the dang think snapped in half.
It seemed to me that it was plastic. I'm curious if it was dried, hardened rubber or if it was plastic. Has anyone seen a replacement for this? I assume I could use a rubber pvc grommet but I would like something correct, or as close to it as possible.
I would like to know a little more about it before I go hunting for an original valve cover just to rob the grommet out of.
Dearborn car, early 65 built 2-9-65. C code.
Russ
65 Coupe 5F07C627703
Sch build date 2-9-1965
Wimbledon White (M) w/ standard palomino buckets (29), 289 2V, C4
53K original miles
Re: Down draft tube grommet - valve cover
« Reply #1 on: March 07, 2015, 05:18:16 PM »
NPD lists a grommet for road draft tube - 6A892-1 $2.10, don't know what it looks like or if it's accurate.
« Reply #2 on: March 07, 2015, 09:27:32 PM »
I thought it was the same one used for PCV valves.
Offline zray
« Reply #3 on: March 08, 2015, 01:18:40 AM »
It is, and it fits perfectly
Z
Looking for '65-'68 manual V-8 coupe
that doesn't need a new body
Offline russgoodman
« Reply #4 on: March 08, 2015, 04:55:49 PM »
Alright, PVC grommet it is. I nearly ordered one of them to try out previously. Is it rubber or plastic? Thanks everybody!
53K original miles
« Reply #5 on: March 08, 2015, 06:13:27 PM »
rubber.
