Author Topic: Rocker Shaft Assembly Orientation  (Read 1808 times)
Offline suskeenwiske
  • 214-347-3628
« on: March 05, 2015, 12:40:16 PM »
Can you imagine having to tear this back down? It suddenly hit me that I never checked the Piston Ring End Gaps.
Question: does anyone know if it matters which way this Rocker Shaft Support is oriented? I rebuilt it the way I found it, in the front, but have since seen photos of the same Support on the back of the Shaft.
Ray
Ray
1965 Dearborn Coupe
6 Cylinder, AT, PB, PS, AC
Est. Build 23A
Offline C5ZZ
Re: Rocker Shaft Assembly Orientation
« Reply #1 on: March 13, 2015, 02:50:16 PM »
Ray, here are some pictures, hope this helps.
MCA # 00945
Rangoon Red/Red Interior
  • 214-347-3628
« Reply #2 on: March 13, 2015, 06:41:47 PM »
Thanks Steve.
Your photos show the support on the front of the Shaft and turned 180 degrees compared to mine. My problem is...should it be on the front of the shaft or on the back and turned which way? I've seen it both ways so maybe it doesn't matter, but because its position potentially affects the oil flow to the Rockers and the return of oil, I want to make sure that I have it where it belongs.
Frankly, I don't even know why it's there at all. I do know that it dumps oil back onto the head through a large hole at a good rate. Is it meant to be a pressure relief of sorts to prevent oil from squirting out of the Rocker Arms? Is it meant to drain the Shaft after engine shutdown for some reason? In which case, should it be on the back since the Engine is slightly tilted? Then again, placing it on the front seems better since it will fill the Shaft first before draining out of the hole which would get oil to the Rockers faster. Is it designed to help prevent sludge buildup by flushing the oil under pressure? In that case it would be better at the front.
I was hoping that we had an engine builder on this site that would know, so far no luck. If I never find out, I'll just have to try both positions to see which provides better oiling to the Rockers.
Thanks again...Ray
« Last Edit: March 13, 2015, 06:44:52 PM by suskeenwiske »
Ray
1965 Dearborn Coupe
Est. Build 23A
Offline WT8095
  • Dave Z.
« Reply #3 on: March 13, 2015, 10:35:18 PM »
The '75 MPC illustration shows the washer on the front support. In section 60.2 it's listed as p/n C0DE 6A508-A. The description reads: "COVER - VALVE ROCKER ARM FRONT SUPPORT OIL PASSAGE". Application is "Before 5/4/66".
A PDF of a vintage Mitchell manual also shows it on the front support:
http://vintage.mitchell1.com/PClubData/chassis/den81/V2D816068.pdf
« Last Edit: March 13, 2015, 10:38:16 PM by WT8095 »
Dave Z.
Offline C5ZZ
« Reply #4 on: March 13, 2015, 11:16:52 PM »
I agree, it should be on the front support, with the way the rockers
are oriented in the picture thats the only way it would go on.
MCA # 00945
Offline C5ZZ
« Reply #5 on: March 13, 2015, 11:21:56 PM »
Ray, its in the front in other pictures I have as well.
« Last Edit: March 14, 2015, 09:25:47 AM by C5ZZ »
MCA # 00945
  • 214-347-3628
« Reply #6 on: March 14, 2015, 06:19:42 PM »
Thanks as always Steve...haven't steered me wrong yet. And also thanks to you for the Link WT8095; just the kind of thing I've been looking for, not just for this but any number of other things.
I won't mention where or who but a nationally known supplier as well as magazine both showed their how-to rebuilds with the Shaft Support on the rear; hence all my confusion.
Thanks again to you both. :)
Ray
Ray
1965 Dearborn Coupe
Est. Build 23A
Offline WT8095
  • Dave Z.
« Reply #7 on: March 14, 2015, 07:39:27 PM »
You're welcome. Glad to help!
Dave Z.
