Author Topic: 1968 mustang fastback trunk paint  (Read 2266 times)
Offline mhubert89
« on: March 05, 2015, 10:49:05 AM »
hi,
what is the spec for the trunk color ?
trunk is body color ?
under trunk door body color ?
trunk door hinge body color ?
gas tank no paint on it ?
what is the correct carpet for the trunk ?
thanks
Mustang Fastback 1968
289, 4 speed
Re: 1968 mustang fastback trunk paint
« Reply #1 on: March 05, 2015, 10:52:26 AM »
entire trunk area is body color. nothing installed, no tank, wiring etc.
Offline mikelj5S230
  • 1964 1/2 K code coupe, 5S230, and 2022 GT500 HE
« Reply #2 on: March 05, 2015, 12:07:40 PM »
Here is a pretty lengthy, thorough discussion about the trunk mat….
http://forums.vintage-mustang.com/concours-forum/588878-68-fastback-correct-trunk-mat.html
I don't always downshift, but when I do it is near a Prius so they can hear me hurting the environment.
« Reply #3 on: March 05, 2015, 02:02:46 PM »
Might try the search features - plenty of prior threads about how cars were painted. Be sure to be year and plant specific
Same as the exterior of the car in areas painted. In the hidden, back corners you may have found bare metal of a light misting of red oxide primer
Trunk lid/door was in place when the car was painted so hinges, lid and all the mounting bolts along with the trunk lid spring and mounting hardware are body color. You didn't include other details as to when and where the car was built but in general there would be to round bare areas at the dolly mounts on each side of the trunk and the bumper guard bracket rear pointing bolts would be in place and painted. Nothing else would have been installed in that area and paint was applied after the seam sealer and sound deadener applied. Type, style and product would depend again on plant
Was not installed at the time
No carpet. Mat will depend on when and where the car was built, depending on those answers could be a couple fo different ones but your not going to be able (with any ease) to find some versions . As shown above do a search and start reading :)
Offline mhubert89
« Reply #4 on: March 05, 2015, 03:08:15 PM »
my 68 fastback was built on april 16th 68 and was from Dearborn !
289, 4 speed
