Author Topic: 68 interior paint / charcoal black metallic !!  (Read 6975 times)
Re: 68 interior paint / charcoal black metallic !!
« Reply #15 on: March 06, 2015, 02:35:22 PM »
for the semi gloss black to put under the VP-4464 , did you recommend a brand ? It's a black primer or can you show me a good stuff to buy for that..really don't know anything about paint !!
You looking for rattle can stuff?
Offline mhubert89
« Reply #16 on: March 06, 2015, 03:18:06 PM »
yes !
Mustang Fastback 1968
289, 4 speed
« Reply #17 on: March 06, 2015, 04:22:59 PM »
yes !
Any decent locally available brand should do. Rustoleum, Krylon.... Test it first on another piece of cardboard or metal to make sure it doesn't lift when overcoated with the charcoal
Offline mhubert89
« Reply #18 on: March 07, 2015, 10:48:42 AM »
perfect ! and what will be the best paint to use on my metal interior parts and also my fiberglass panel from NPD ? AP-4464 OR VP-4464 ?
289, 4 speed
« Reply #19 on: March 07, 2015, 05:37:15 PM »
If you read the description the VP is made for vinyl and flexible plastic parts.  AP - 4464 is for the panels you have listed in this thread
Offline mtinkham
  • That'll be easy
« Reply #20 on: November 18, 2015, 01:47:04 PM »
The AP-4464 is a lacquer based product.  When precoating the dash and door areas with the semi-gloss black, I am assuming another lacqure based product is used - correct?  Is there any negative interactions with the EDP coated repro-panels and the lacquer?  I will test this weekend, but developing my plan now.
« Reply #21 on: November 18, 2015, 05:11:55 PM »
I don't use a primer - don't want anything that will fill the grain and primer is often designed to fill flaws but everyone has their own method.
Allot depends on what is available locally - sometimes I've used Hot rod black other times rattle can like Krylon
Just me
