Author Topic: 68 interior paint / charcoal black metallic !!  (Read 6977 times)
Offline mhubert89
« on: March 04, 2015, 08:15:06 AM »
hi,
can someone told me wich paint i can use to my charcoal black metallic interior for my 68 fastback ?
anyone have the formula mix from dupont or ppg ? Because here in canada, not all paint are available or legal !!
thanks
Math
« Last Edit: March 04, 2015, 09:24:59 AM by carlite65 »
Mustang Fastback 1968
289, 4 speed
Re: 68 interior paint / charcoal black metallic !!
« Reply #1 on: March 04, 2015, 10:32:36 AM »
The PPG number should be 32586.
Offline mhubert89
« Reply #2 on: March 04, 2015, 12:01:18 PM »
yes i know that but i need the formula mix because this code cant be found here in canada..illegal for my country ! So with the formula i we will be able to ask the dealer to do it !!
thanks
289, 4 speed
« Reply #3 on: March 04, 2015, 04:44:10 PM »
thanks
FYI  I have yet to see the product cover well regardless of MFG. Many have found it helpful to lay down a light coat of black as a base coat before applying the Dark charcoal Metallic top coat. This keeps from having to lay down too thick a coat of the DCM which in the case of any area that has a grain ,the thicker application has a tendency to fill in the grain giving the wrong look . If someone hasn't done this before or has but isn't aware of the consequences then it could be a problem for you. Something you may or may not want to confirm with your "Dealer". The best of luck with your project.
« Reply #4 on: March 04, 2015, 05:02:38 PM »
As mentioned in many previous threads you might try Auto Color Library and check to see if they will ship to Canada.
If they do its up to you if you choose to use or shot it.
« Reply #5 on: March 04, 2015, 08:02:23 PM »
thanks
I used to work for a global food manufacturing company. Most formulas and processes are closely guarded secrets. In this case it would be dependent on specific manufacturers ingredients to get a desired results.
PPG is illegal in Canada, or importing paints is illegal?
« Last Edit: March 04, 2015, 08:04:54 PM by krelboyne »
Offline mhubert89
« Reply #6 on: March 04, 2015, 10:31:43 PM »
We have PPG paint over here but the PPG 32586 is unavailable over here, something with the environnement laws..so we can't have the formula for the mix ...yes i think i can order paint from usa, just need a place to order this paint !
and do you use the same paint for the dash, door and fiberglass panel ?!
289, 4 speed
Offline mhubert89
« Reply #7 on: March 04, 2015, 10:47:50 PM »
i check with a usa compagny and they offert this paint in this 3 options :
ppg basecoat or our restoration shop paint in base coat or singles stage ...?
can i use one for all the metal like dash, door and the fiberglass panel too or i need 2 different paint ?
289, 4 speed
« Reply #8 on: March 04, 2015, 11:08:45 PM »
Would use a single stage - multiple coats means less grain detail. Then your just wasting your time for a restoration
Some paitn can be used on all the interior sheet metal and fiberglass/plastic panels
Offline mhubert89
« Reply #9 on: March 04, 2015, 11:23:02 PM »
perfect !
appreciate , thanks
289, 4 speed
Offline mhubert89
« Reply #10 on: March 05, 2015, 09:01:57 AM »
does anyone have try the spray can from NPD vp-4464 it's the vinyl dye !? how the color ??
289, 4 speed
« Reply #11 on: March 05, 2015, 02:04:21 PM »
For the metal/fiberglass?   Or for the arm rest or seats?
Offline mhubert89
« Reply #12 on: March 05, 2015, 03:04:00 PM »
for the metal \ fiberglass !
but does the color of this spray can are very close to original or not really ?
289, 4 speed
« Reply #13 on: March 05, 2015, 03:51:05 PM »
Did see a mention on my link of being a vinyl dye - just as "Mustang INTERIOR PAINT, SPRAY, LACQUER, 67-73 BLACK METALLIC (ACTUALLY IT S DARK CHARCOAL METALLIC AS ORIGINAL)"
Believe its very similar to what I've used from them before. As mentioned in other threads. Apply it over a thin base of semi-gloss black, then two light dry full coats of the Dark Charcoal Metallic. Wet heavy coats will fill up the grain. I still need to redo one of my cars since I did just that 25 years ago on it.    .... Yes I'll get to it one day  ::)
Offline mhubert89
« Reply #14 on: March 06, 2015, 09:56:34 AM »
for the semi gloss black to put under the VP-4464 , did you recommend a brand ? It's a black primer or can you show me a good stuff to buy for that..really don't know anything about paint !!
289, 4 speed
