Author Topic: 67 Smog Intake Canister and Hoses  (Read 2715 times)
Offline travnemi
  • Travis Waters
« on: March 03, 2015, 01:00:37 PM »
Hey there!
    I had some questions on the smog system on a 1967 Mustang Fastback GTA S Code San Jose built and a build date of December 1966.
   Should the Smog Air Intake Canister strap and wing nut be cadmium plated and the bracket and canister semi gloss black?
    Also would there be a point deduction for using donor hoses to complete the smog system?
Thanks for all your help,
Travis Waters
« Last Edit: April 23, 2016, 10:45:02 PM by J_Speegle »
Travis Waters
Mine -
1967 Mustang GTA S Code, Fastback, San Jose, Built Dec. 13, 1966 (Thermactor)
Daddy / Daughter Project -
1967 Mustang S Code, Fastback, San Jose, Built Sept. 9, 1966
Re: Judging Smog Intake Canister and Hoses
« Reply #1 on: March 03, 2015, 06:27:44 PM »
Can lid and wing nut were originally painted as a unit. The paint didn't stick as well to the plated wing nut so often after all these years there is little left. Sort of like what happens to the master cylinder lids
In judging it depends on the class. If in Concours Trailer or Driven the judges should ignore the ink markings on hoses and the owners should make an effort to remove any incorrect - distracting markings so it will not tempt a judge to deduct.  Just make sure the ends are cut as they would have been originally, the hose looks and is shaped like the original one.
Offline travnemi
  • Travis Waters
« Reply #2 on: March 03, 2015, 09:22:07 PM »
The strap is the same color as the unit (everything on that canister is semi gloss black)?
Thanks again,
Travis
Travis Waters
Mine -
« Reply #3 on: March 03, 2015, 09:36:01 PM »
No its zinc dichromate in look and finish. Wasn't attached to the can when painted though allot of cars had them painted by owners over time. Clamp is not used through the whole year - depends on when the car was built, a result of all running changes effecting the Thermactor system
Offline travnemi
  • Travis Waters
« Reply #4 on: March 03, 2015, 09:44:54 PM »
Thank you for your information!!!
Travis
Travis Waters
Mine -
Offline travnemi
  • Travis Waters
« Reply #5 on: April 19, 2016, 10:09:41 AM »
Does anyone know what size the bolts were to mount the canister to the shock tower. Also, were the nuts on the back or was the shock tower threaded?
Travis
Travis Waters
Mine -
« Reply #6 on: April 19, 2016, 12:43:52 PM »
No bolts were used - instead two hex headed screws were used to attach.
Will see if I have a clear picture and maybe a head mark
Offline travnemi
  • Travis Waters
« Reply #7 on: April 19, 2016, 03:29:14 PM »
Thanks Jeff
Travis Waters
Mine -
« Reply #8 on: April 19, 2016, 04:21:52 PM »
I'll bet the info you're looking for is in the forum's Library under Mustang Hardware Spreadsheets for 67 and 68 and can be see in the file sorted by application.
Offline preaction
« Reply #9 on: April 19, 2016, 06:46:24 PM »
Jeff, when the word strap is used in this context is this the bracket that holds the air filter canister to the fire wall that is zinc dichromate ?
« Reply #10 on: April 19, 2016, 10:23:04 PM »
"holds the air filter canister to the fire wall that is zinc dichromate"
Holes the filter to the passenger shock tower bracket or to another bracket depending on when the car was built
And yes the finish of the clamp was zinc dichromate
Offline travnemi
  • Travis Waters
Re: 67 Smog Intake Canister and Hoses
« Reply #11 on: April 23, 2016, 04:16:52 PM »
Jeff what was the finish to the Hex Head Screws also were they slotted?
Travis
« Last Edit: April 23, 2016, 10:45:18 PM by J_Speegle »
Travis Waters
Mine -
« Reply #12 on: April 23, 2016, 10:54:33 PM »
Same as the strap and the nut- zinc dichromate
Yes it's a hex head with a standard slot
Ps moving the thread since it really has nothing to so with MCA or Judging
