Author Topic: 68 fastback interior bracket  (Read 7960 times)
Re: 68 fastback interior bracket
« Reply #15 on: March 02, 2015, 04:20:16 PM »
wich bracket its the good one for the buttom section of the seat..i saw 2 differente bracket !!
Top example in your post - your looking at pictures from different types of cars - adding to your confusion
the first picture its the bracket inside the orange line
Yes
Offline mhubert89
« Reply #16 on: March 04, 2015, 08:09:31 AM »
Yes
that weird because the white floor its really from a 68 fastback..it's a forum for a full restoration for this 68 !
Mustang Fastback 1968
289, 4 speed
« Reply #17 on: March 04, 2015, 02:33:12 PM »
In both of the examples you showed someone has been in there before - not unrestored - altered. The seat cushion "hooks" on the white example are the style not normally used on fastbacks but on other body styles in 68. Maybe someone got confused or missed this detail when they rebuilt the cars body.
Also consider that the taller brackets would not work very well with the very thin (when compared to the coupe and convertible) lower cushions - too tall for such a thin fastback cushion and frame.
So the question would be is the white floor originally from a 68 fastback or just what is there when they took the picture? One of the challenges/problems  IMHO of using "restored" cars as references. Looks like someone made a mistake - hopefully you've not been using this example for a guide for your restoration. ::)
« Last Edit: March 04, 2015, 05:14:08 PM by J_Speegle »
Offline mhubert89
« Reply #18 on: March 04, 2015, 10:34:02 PM »
yes perfect , thanks for your help..just want to make sure to do it good the first times...and 67-68 mustang are very rare over here..it's hard for me to go see one unrestored !
289, 4 speed
« Reply #19 on: March 04, 2015, 11:07:24 PM »
..............it's hard for me to go see one unrestored !
Not really - they are as close as your computer and this site ;)
Offline mhubert89
« Reply #20 on: October 11, 2015, 09:49:36 PM »
Hi , the interior trims bracket that go under the rear glass , did they are the sames of the one on each side of the roof or longer ?
289, 4 speed
« Reply #21 on: October 11, 2015, 10:42:59 PM »
Look pretty close - sorry don't have any to measure right now
Offline mhubert89
« Reply #22 on: October 11, 2015, 11:10:46 PM »
Yeah look really similar , tahnks !
And do you know where do the little one ? ( up right in the picture ?)
289, 4 speed
« Reply #23 on: October 13, 2015, 07:34:00 PM »
No idea at the moment
Offline Fastback2013
« Reply #24 on: October 14, 2015, 03:01:13 AM »
Could it be the base for mounting the front bracket for the rear view mirror attachment?
Just a thought ?
Remember I have a 67 Fastback, not sure if it is 100% the same.
Hope this helps,
Kind regards,
Jeroen
San Jose 7R02C1708xx
Fastback GTA
built on 01/12/1967
« Reply #25 on: October 16, 2015, 04:34:21 PM »
Though its a bit off topic - yes
Offline WT8095
  • Dave Z.
« Reply #26 on: October 16, 2015, 07:29:45 PM »
Just a thought ?
I don't think it's a match, see the side-by-side comparison. Even if it did, it wouldn't apply to Mathieu's '68 - the mirror mounted to the windshield glass starting in '68.
Dave Z.
« Reply #27 on: October 17, 2015, 06:37:25 PM »
Remember its a reproduction part - it doesn't have to match - or look the same - just fill a need.  Measurement of the two (if we had that) would help
Offline WT8095
  • Dave Z.
« Reply #28 on: October 17, 2015, 10:05:38 PM »
Good point. If that's the case, they did much better reproducing the other brackets.
Did a bit of looking at those bracket kits. The ones listed for 65-66 show the same piece. Maybe they copied a 65-66 bracket and included it in their 67-68 kit? I couldn't find any photos of a 65-66 bracket to compare (assuming they even had them...).
Dave Z.
