Author Topic: 68 fastback interior bracket  (Read 7959 times)
Offline mhubert89
« on: February 25, 2015, 07:35:33 PM »
hi,
can someone have a plan or all the measures for the interior floor bracket for the fold down seat ?
i have a 68 fastback !
thanks for your help !
Mathieu
Mustang Fastback 1968
289, 4 speed
Offline mhubert89
Re: 68 fastback interior bracket
« Reply #1 on: February 26, 2015, 03:07:36 PM »
nobody have picture to show me where all the floor bracket ( fold down seat ) go in a 68 fastback ?
289, 4 speed
« Reply #2 on: February 26, 2015, 09:12:00 PM »
Offline mhubert89
« Reply #3 on: February 27, 2015, 01:15:39 PM »
hi, thanks for your picture...do you have all the other brackets..have 3-4 on the floor just behind front seat and somes on the wheelhouse !?
Mathieu
289, 4 speed
« Reply #4 on: February 27, 2015, 05:39:26 PM »
These would be the forward most brackets attached to the floor - two more (can see one in one of the pictures) right in front of the rear fiberglass/plastic side panels  for the rear section of the floor cover. The one bracket on each of the wheel wells.
There are two brackets on the floor under the rear seat but those are not for the fold down.
Will not have access to the car again till next visit - next week
Offline mhubert89
« Reply #5 on: February 27, 2015, 09:33:09 PM »
just not sure where go 4-6 bracket because i think mine where missing on my old floor , will try to show you wich one !
in the picture ..if you start from the right , the first bracket in the second row..have 2 identical with 4 holes on the side
after that the last one at the bottom left ..have 2 little ''s'' 2 have a littles hole at our left and 2 others bracket no hole . Have 4 brackets that look very similair ...
thanks and sorry for the poor explication, i am french spaeking !
Mathieu
289, 4 speed
« Reply #6 on: February 27, 2015, 10:09:10 PM »
Mathieu,
I believe what you are asking about are brackets for the rear seat, lower section.  Attached is a picture with the area highlighted in red.  These would be the same for any body style I think.  If you need dimensions I would be able to do anything for about a week, perhaps someone else can.  This is for the ones with the four holes.
For the others, I'm not quite following.  Can you edit the picture you posted in MS paint or similar program, modify by highlighting the bracket(s), and reposting?
bienvenue sur le site
« Last Edit: February 27, 2015, 10:12:02 PM by 67gta289 »
« Reply #7 on: February 27, 2015, 10:32:01 PM »
Ok lets try this From memory and using your picture. Sure others will help out if I miss something
Without an original car to measure you have a tough job. If any one of these is off by a couple of milometers panels attaching to them will not fit and you'll have to remove and re-weld it. And you normally don't find out until the car is painted and going back together.  Saw this in a shop 2 weeks ago and the upper fold down brackets were not in the correct place on the wheel well
Green- Brackets that screw to the body and hold interior panels. Not certain of the two in the upper right
Red - Fastback package area brackets
Light blue- Bracket that attaches to the passenger side trap door opening. Engages with the arm on the trap door to keep it open
Dark blue - these look like the screw on brackets that will attach to the two rear roof panels that go overhead on a fastback
Yellow - These appear to be the sun visor brackets that weld to both front corners of the roof above the headliner
Orange - Rear bottom seat cushion brackets that weld to the floor
This is one of the reasons I don't build cars with rust  8)
Offline mhubert89
« Reply #8 on: February 27, 2015, 10:43:20 PM »
first ! thanks to take times to help me, very appreciate !!
oki for the orange ! that help me ..
the others bracket that i need to know its between the green and blue , have 3 littles brackets !?!?!
289, 4 speed
« Reply #9 on: February 28, 2015, 04:16:40 AM »
The top pair looks like they may be for the top rear edge of the rear seat lower section -  The form sort of a hook with the bottom end (once attached) open where the frame of the lower section slides into and is held between the "hook"/bracket and the floor of the car.
Pictures is not great can't make out the one on the bottom of that group
Offline WT8095
  • Dave Z.
« Reply #10 on: February 28, 2015, 09:45:17 AM »
The dark blue are for the rear over head panel as you speculated. The green ones in the upper right are interior panel attachment points at the beltline just behind the doors. Please excuse the extra red oxide primer, courtesy of a P.O.  :)
Dave Z.
Offline WT8095
  • Dave Z.
« Reply #11 on: February 28, 2015, 09:56:46 AM »
Yes, the top ones are as you described. I don't have a photo showing the entire bracket, just the hooked ends peeking out below the seatback material.
I don't recognozie the bottom one either, but it appears to be the same design as the one on the far left in the lower left green box.
Dave Z.
Offline mhubert89
« Reply #12 on: March 01, 2015, 02:52:01 PM »
yes for the 2 brackets like hooks , but 2 brackets are same like the hook but have 2 littles hole upper left ! one are in the green square in the other one are with the 2 others hook between the green and blue !?
289, 4 speed
« Reply #13 on: March 01, 2015, 04:15:46 PM »
Yes I see the other match to the bottom one between the green and blue box that has not be identified. Picture is too poor and at a bad angle for me to figure out where they go
Offline mhubert89
« Reply #14 on: March 02, 2015, 11:55:23 AM »
wich bracket its the good one for the buttom section of the seat..i saw 2 differente bracket !!
the first picture its the bracket inside the orange line
289, 4 speed
