Author Topic: Buck Tag - 69 Dearborn  (Read 7379 times)
Offline 13Outlaw
« on: February 23, 2015, 11:55:57 PM »
Does anyone know what all the numbers stand for on the Buck  tag. I know of course the VIN body an paint code, but not sure what the other numbers are an why it doesn't have the trans code? For instance what is the "452" "RM" "RAC" H-2 R-2? Thanks
 Thanks for any info
« Last Edit: February 25, 2015, 06:12:11 AM by J_Speegle »
1969 Mach 1 R-Code 4-Speed (Dearborn built Jan 69)
1992 GT 5.0 5-Speed
2003 Cobra
2013 Shelby GT500
Offline Coralsnake
Re: Buck Tag
« Reply #1 on: February 24, 2015, 02:35:46 AM »
« Last Edit: February 24, 2015, 02:38:53 AM by Coralsnake »
Offline 13Outlaw
Re: Buck Tag
« Reply #2 on: February 24, 2015, 08:35:40 AM »
Thanks for the info guys, that makes sense on the mirror. I'll plan to buy the book, it will be cool to have. Thanks again.
Shane
1992 GT 5.0 5-Speed
2003 Cobra
2013 Shelby GT500
priceless
  • Guest
Re: Buck Tag
« Reply #3 on: February 24, 2015, 08:48:11 AM »
Just thought I would add a photo of my original Buck tag and what Marti said the letter information stood for.
1969 Mach1, 2/24/69,  Metuchen built. Yes 46 years ago today the Mach was built :)
 I'm assuming the "71" is some sort of rotation number, he didn't say. I know it's not the DSO cause my Mach1 was delivered to the Charlotte DSO (22).
GT=GT suspension, TT=Tu-Tone hood, CL=courtesy lights in doors, RM=remote mirror, MO=rocker molding, HP=hood pins
and 3S=internal plant code.
« Last Edit: February 24, 2015, 08:54:37 AM by priceless »
Re: Buck Tag
« Reply #4 on: February 24, 2015, 11:06:57 AM »
Nice looking Buck tag.  The Marti Tag Book is a great resource book all though a bit difficult to understand when describing the buck tags.  Yes the 71 is a rotation number and is more correctly referred to as the Body and Paint sequence number.  Brian
« Last Edit: February 24, 2015, 11:11:06 AM by Brian Conway »
Offline 13Outlaw
Re: Buck Tag
« Reply #5 on: February 24, 2015, 07:22:10 PM »
Does my buck tag look different because of the plant it was built at, I've seen a lot with the jagged edges...
1992 GT 5.0 5-Speed
2003 Cobra
2013 Shelby GT500
Re: Buck Tag
« Reply #6 on: February 24, 2015, 09:40:07 PM »
Your tag location and square edges, is typical for Dearborn in 1969/70.
Offline 13Outlaw
Re: Buck Tag
« Reply #7 on: February 24, 2015, 10:18:48 PM »
Awesome, thanks!
1992 GT 5.0 5-Speed
2003 Cobra
2013 Shelby GT500
Re: Buck Tag
« Reply #8 on: February 25, 2015, 05:45:04 AM »
Yes plus the codes differ from plant to plant and between different time periods
Re: Buck Tag - 69 Dearborn
« Reply #9 on: February 25, 2015, 06:13:45 AM »
It doesn't have the trans info since that didn't matter to the guys that would use the buck tag on the line.  Remember this tag was to help instruct line workers during the first half of the assembly - body and trim. So things than needed holes or different brackets is what was important
452 would be the cars first rotation number (as mentioned) the odd H2 R2 were inspections if I recall correctly
Rocker molding and painted mirrors would be the others
Offline 13Outlaw
« Reply #10 on: February 25, 2015, 10:07:27 AM »
Jeff,
Thanks for the info! That makes sense on the trans code, never thought of the obvious.
Thanks again!
Shane
1992 GT 5.0 5-Speed
2003 Cobra
2013 Shelby GT500
« Reply #11 on: February 25, 2015, 12:40:37 PM »
jeff at what point in the assembly line did they need to know about 4-speed to punchout the clutch rod firewall hole & install the 2 nuts in top framerail for the z-bar bracket & which 2 out of the 3 holes to install the 2 nuts depending on engine option but that would be known by the 5th letter in the serial # already on bucktag ?   just wondering :)
« Last Edit: February 25, 2015, 12:46:16 PM by specialed »
« Reply #12 on: February 25, 2015, 03:59:54 PM »
Don't think this has anything to do with the engine code since that could not be addressed in that fashion for a cars other than the Boss's. All the rest of the engines could have been ordered with an automatic or a manual
The frame nuts, I believe would have been addressed when  the frame rails were assembled as a sub assembly, especially since they are installed from the inside of the inner frame section. Not sure if they arrived at the car assembly plant but my guess would be that they were shipped that way.  Well before the frame rails were added to the unibody is my guess.
As far as the manual trans firewall punch out - its interesting that earlier cars had a designation on the buck tags for the manual trans (nothing for the auto)  but this was dropped by the time 69 came around on Dearborn and NJ buck tags. My thought is that something change - either this was being addressed in another way or much earlier in the process before the buck tag was attached to the unibody
« Reply #13 on: February 25, 2015, 05:30:42 PM »
by engine code id I meant knowing what engine was going in car would determine which 2 holes to install the nuts in as their are 3 holes for the equalizer bar frame bracket & either the 2 front or 2 rear holes would be used depending on engine size also under lh frame rail are 2 holes for p/s cast bracket & they are the same size & type nuts as z-bar frame bracket & if no factory p/s these 2 lower holes never got the 2 nuts installed
« Reply #14 on: February 25, 2015, 06:16:44 PM »
Ok now I understand what you were trying to communicate. Thing this was addressed as mentioned in the sub assembly process before the car assembly began or before a buck tag for a specific car was stamped. Sort of like having available different fenders would have been preassembled before they arrived at the cars  plant
