Author Topic: Luggage Guard Glue  (Read 1169 times)
Offline ChrisV289
Luggage Guard Glue
« on: February 20, 2015, 07:07:57 PM »
What type of glue is used for the plastic guard on the driver side?  Is it the same that is used for the weatherstripping?
2009 V6 Mustang Coupe
Re: Luggage Guard Glue
« Reply #1 on: February 20, 2015, 07:08:45 PM »
yes. yellow w/strip glue.
Offline ChrisV289
« Reply #2 on: February 20, 2015, 07:12:24 PM »
Thanks!  Always curious as to why they didn't put one on the passenger side....If it was to protect the luggage from sharp edges, wouldn't you want the spare tire also protected??  :o
« Reply #3 on: February 20, 2015, 07:29:17 PM »
+1  Use the yellow/brownish clear stuff wiped with a 1/2-3/4" wide chip brush. Often the area covered by the glue is larger (towards the viewer) that the thin strip of rubber and it allows for quick viewing for judges if entered in a show.
65 example - just a little glue showing
66 example - worker here missed the pinch weld of the wheel well by a couple of inches on the first try :( Must not have been looking
.....If it was to protect the luggage from sharp edges, wouldn't you want the spare tire also protected??  :o
The spare tire works as a luggage protector from the other side and it doesn't move around once in place correctly - so no damage would be expected to the tire
« Reply #4 on: February 20, 2015, 08:20:24 PM »
Look for yellow neoprene adhesive on ebay, it's an amber color like original.  Comes in small cans with brush attached to top cap.
