Author Topic: 1970 428 CJ Manual Choke Carburetor  (Read 4572 times)
Offline wjgrnp
« on: February 18, 2015, 10:28:59 PM »
Hi
I have recently purchased the correct Carburetor for my 70 Mach 1.
I am having diffuculty finding any photos of the factory setup for the Carburetor.
Mine has AC so i have the throttle solinoid however am not certain about instillation of the Dashpot and the Choke & Fresh Air Tubes I have seen in Photos of the automatic choke setup but none of the manual choke.
If anyone has some Photoes or comments they would be greatly received.
Thank you
Ward
« Last Edit: February 19, 2015, 06:46:35 PM by J_Speegle »
70 Mach 1 428 CJ with AC and C6
3.25 with Truetrac limited slip
Metuchen
December 30 1969
Yellow
Offline 70cj428
Re: 1970 Manual Choke Carburetor
« Reply #1 on: February 18, 2015, 11:01:25 PM »
Not sure what your asking, but all the 70 carbs use a manual choke setup (with a cable) so there's no auto choke, or the associated choke hot air tubes. Your carb uses the electric solenoid, so no dashpot either. I'm away from my stuff till the weekend, but if someone doesn't beat me to the punch, I can post some pic's of the right setup. ( I have a 9/30/69 Metuchen 428 AC mach1)
Tons of good info here on the 428CJ site, here's the link, hope Scott doesn't mind...
Your carb should look just tike the one in the first pic....
http://www.428cobrajet.org/id-carb
« Last Edit: February 18, 2015, 11:04:44 PM by 70cj428 »
Offline wjgrnp
« Reply #2 on: February 19, 2015, 12:20:24 AM »
Thanks John
The photos would be very helpful.
 I am also having difficulty fully understanding the Throttle Cable Bracket DOOZ-9741-D and the Throttle Cable Assembly - a picture tells a thousand words.
Many thanks
Ward
Metuchen
December 30 1969
Yellow
Offline Mike_B_SVT
« Reply #3 on: February 19, 2015, 12:45:46 PM »
I'll dig through my pics and see what I have that may be useful, if no one else posts before then.  If I can't find anything, I'll try to snap some pics tonite after work.
Mike B.
1 of 354 in Sonic Blue
Cat Bites Man!
Offline wjgrnp
« Reply #4 on: February 19, 2015, 06:04:54 PM »
Thanks Mike
Regards
Ward
Metuchen
December 30 1969
Yellow
Offline Mike_B_SVT
Re: 1970 428 CJ Manual Choke Carburetor
« Reply #5 on: February 19, 2015, 07:57:30 PM »
Ok, the only pics I have handy are close ups of the manual choke cable attached on the side of the carb - which I think is what you are after.
I also have some that I took when I was removing the manual choke actuator, so that I could make sure I put it back on correctly.  If you need to see those, let me know.
Mike B.
Cat Bites Man!
« Reply #6 on: February 20, 2015, 07:18:31 AM »
I'm no CJ or SCJ expert but I have worked on many Fords of the era. In Mike's picture, shouldn't the choke cable (wire connecting to the carb)  be straight as an arrow? (meant to read, not bent upwards) Just an observasion but to me it looks odd that way, I'm sure it works right though.
Richard
Offline rayms69
« Reply #7 on: February 20, 2015, 10:51:44 AM »
i was thinking the same things, hate to get poked
10-26-1969 Dearborn 428 SCJ auto
« Reply #8 on: February 20, 2015, 01:28:44 PM »
also the holley transfer tube should be routed the other way as the offset bend was from rear from factory to clear pcv fittings in that pic as it will work both ways but the extra bend was originally in rear.  just sayin as look how close tube is to vaccum tree fitting.
« Last Edit: February 20, 2015, 01:48:13 PM by specialed »
Offline Mike_B_SVT
« Reply #9 on: February 20, 2015, 04:26:35 PM »
Thanks for the tips fellahs, I appreciate it!
Mike B.
Cat Bites Man!
