Author Topic: Why did Ford use Blue Nuts on their Struts?  (Read 4340 times)
Offline 79mustangcobra
« on: February 18, 2015, 01:20:09 PM »
I was looking at this 300 mile 79 Pace Car I use for a reference on my restoration and wondered why Ford used Blue nuts on the struts?
Was it for the warranty?  For a quick visual?
Please see picture below - thanks!
1979 Mustang Cobra 5.0
2P Red and 1C Black
Stock never goes out of style
MCA #70281 -  79-93 MCA Concours Judge
Proverbs 3:5-6
Offline rodster
Re: Why did Ford use Blue Nuts on their Struts?
« Reply #1 on: February 18, 2015, 07:47:23 PM »
Don't know, but Ford also used blue nuts some places on SVO's too.  Don't think struts was one of them tho.  Interesting picture.
1965 Dearborn Mustang Coupe
Raven Black - Palomino Pony
1967 Dearborn Mustang Conv.
Wimbeldon White - Red
1984 SVO - 2A
Offline svo2scj
« Reply #2 on: February 19, 2015, 09:43:51 PM »
Call out for attention to TORQUE spec.
Guns were matched at station
Offline rodster
« Reply #3 on: February 20, 2015, 12:27:37 AM »
I can understand that for the strut nuts, but the small miscellaneous SVO nuts?
1984 SVO - 2A
Offline Smokey 15
« Reply #4 on: February 20, 2015, 12:45:45 AM »
 The cars with the blue ones were built by married guys, maybe?
 Seriously, could just be what was available from the supplier at that time.
« Reply #5 on: February 27, 2015, 06:13:45 PM »
That's cool, thanks for the info.
2P Red and 1C Black
Proverbs 3:5-6
« Reply #6 on: April 22, 2015, 04:35:48 PM »
Well after reading this months Hemmings Muscle I 'May' have an answer
They had an article on this 1979 Oldsmobile Hurst/Olds
So is this the reason the nuts were blue on the 79 Mustang's Struts?
2P Red and 1C Black
Proverbs 3:5-6
Offline Smokey 15
« Reply #7 on: April 22, 2015, 07:13:14 PM »
 That is true. I have owned quite a few GM "G Bodies" and they had a mix of S.A.E. fasteners and metric.  The metrics were blue. I still have some of them.  Not sure if that applies to Ford, but it makes perfect sense.
« Reply #8 on: April 23, 2015, 10:15:53 AM »
I may be barking up the wrong tree, not sure of my 'hypothesis" we shall see.  Thanks! :)
2P Red and 1C Black
Proverbs 3:5-6
Offline svo2scj
« Reply #9 on: April 23, 2015, 04:39:30 PM »
I maintain that it was just a TORQUE call out.      While the struts were important to be torqued to a specific torque , other "blue" bolts were different torques.
On the assembly process sheets these nuts are footmarked with ^ and torque amounts.    In the case of the alternator brace added to the 85.5 SVO they used a blue nut - front on steel alternator bracket is 18-22 FT LBs, while the back of the brace on the manifold stud to alum (blue) is 6-9 ft lbs.    CARE was to be used. That same care needed to be used on the rubber issolators of the VAM - in that case LOW torque 6-9 Ft Lbs.
Probably the best area for this (and missed by mechanics) is the Knock Sensor - called out to 6INCH LBS !   (over tighten an they don't even work)
Mark
P.S.  Not the first time dye was used as call out - look at the steering box bolts on early Mustangs (red) - again critical torque area.   (ever seen a collapsed frame rail from over tightening)
« Last Edit: April 23, 2015, 06:18:36 PM by svo2scj »
« Reply #10 on: April 24, 2015, 03:43:27 PM »
Mark
That is a good point Mark!  I am going to have to dig deeper.  Thanks for your input!
2P Red and 1C Black
Proverbs 3:5-6
