Author Topic: NOS shock paint markings  (Read 5222 times)
Offline 1969 Cale II
« on: February 18, 2015, 12:29:00 AM »
How many people here have gotten nos shocks that had paint marks on them? I have 3 different ones for my Cyclone and the paint is brushed on and it is FLAT not gloss. On suspension parts you can tell it had a gloss, but these shocks are flat. How are the mustang shocks done? Generally speaking.
Re: NOS shock paint markings
« Reply #1 on: February 19, 2015, 05:54:56 PM »
Have seen the markings typically done in a semi-gloss finish. Would not surprise me to find them either in a  flatter or shinier finish since this was likley just the cheapest marking paints the outside vendor could find to use for the purpose.  Also consider if your comparing NOS ones the elements that the part was exposed to, box rub or sitting  as well as other things could effect what finish we are seeing 40-50 years later  Just a thought
« Reply #2 on: February 19, 2015, 06:15:19 PM »
Additionally NOS parts may or may not be exactly like assembly line parts.
Offline WT8095
  • Dave Z.
« Reply #3 on: February 20, 2015, 09:38:57 PM »
...the cheapest marking paints the outside vendor could find to use for the purpose...
This is straying a bit from the original topic, but were paint marks on suspension components generally applied by the part manufacturer, or after they were received at Ford? Or did this vary by year, part, plant, supplier, etc.?
Dave Z.
« Reply #4 on: February 21, 2015, 08:07:53 PM »
By and at the supplier, contractor or sub contractor
Pretty consistent in general it appears though a new supplier coming into the system or one dropping out for a particular plant would make a difference
With that said the specifications for marking could change for all suppliers of a particular part of spelled out in the specifications and a change. Sometimes a paint mark indicated a campaign part or a new and improved part after a problem or issue with earlier parts.
Offline WT8095
  • Dave Z.
« Reply #5 on: February 21, 2015, 10:12:27 PM »
What's a campaign part? I haven't heard that term before.
Dave Z.
« Reply #6 on: February 21, 2015, 10:30:50 PM »
Ford in house term for what we now call a recall. The "campaign" was the process to announce, supply the parts to the dealers and to fix what ever the issue was. The boxes of the "new" improved parts often carried a sticker on the box indicating the campaign in the early years. Believe I still have a box that includes all four tie rods for a 66 that apparently was part of a campaign. Normally they were boxed individually unless they were part of a large kit - like in this example converting a car from manual steering to power
 Not sure if they had "silent" recalls back then or if all were public
Offline WT8095
  • Dave Z.
« Reply #7 on: February 21, 2015, 11:13:31 PM »
Interesting, thanks!
Dave Z.
