Author Topic: 1967 Mustang Smog Pump Question  (Read 1229 times)
Offline travnemi
  • Travis Waters
« on: February 14, 2015, 12:47:49 PM »
I have a question on a 1967 Mustang 390 GTA Dec 1966 build Smog Pump.
1 - What does CFB 1 stand for?
2 - What color is the back plate supposed to be?
3 - how do I tell if I have the correct pump for a 390? (Its stamped July 1966)
Thanks for your help,
Travis
Travis Waters
Mine -
1967 Mustang GTA S Code, Fastback, San Jose, Built Dec. 13, 1966 (Thermactor)
Daddy / Daughter Project -
1967 Mustang S Code, Fastback, San Jose, Built Sept. 9, 1966
Re: 1967 Mustang Smog Pump Question
« Reply #1 on: February 15, 2015, 05:58:08 PM »
Where did you find it on the pump?  Stamped or cast?
If stamped I would venture that it's a rebuilders ID stamp
Semi-gloss black with bare metal machined surfaces
Pumps can be converted to different uses/applications a complete ready to use 67 390 will have three attachment points on the rear plate, the correct size pulley on the front and the specific valve on the side. Believe no shield or diverter on the valve for your application
Offline travnemi
  • Travis Waters
« Reply #2 on: February 15, 2015, 07:11:04 PM »
Thank you, the date code was cast into it and I found it on eBay.He Said he rebuilds them for a living. I still need to do some work on it. It does have the three ports on the back. Do you know where I can get a new side valve.
Thanks again,
Travis
« Last Edit: February 15, 2015, 07:14:54 PM by travnemi »
Travis Waters
Mine -
« Reply #3 on: February 16, 2015, 12:12:38 AM »
Found the CBF 1 you mentioned when I pulled up some pictures from my collection. Cast into the front surface by the casting date . You mentioned that you were looking at a stamped date so I'm guessing you were not referring to the casting date that is on the face also of the early style pumps
"CBF 1" I believe has something to do with the supplier. May/most of the Thermactor parts were not made by Ford but by suppliers and sub contractors like allot of each car
Never have had a need for a pump valve.  Guess I would start by finding one of the places that rebuilds them, likely available since some of the parts houses have been altering late model pumps by drilling holes in the cases and adding them, only to sell them on Ebay aas originals. Sometimes   ::)
