Author Topic: 70 A/C evaporator hose  (Read 1617 times)
Offline machm1970
« on: February 13, 2015, 09:44:13 AM »
I'm in the process of rebuilding my a/c evaporator case. I noticed the hole in the floor where the evaporator hose goes through is just a rough hole, it almost looks like someone punched a hole through the floor with a large phillips screwdriver or something. There isn't a grommet or anything, is this how it's supposed to be?
Matt
« Last Edit: February 15, 2015, 05:48:30 PM by J_Speegle »
Offline sah62
Re: A/C evaporator hose
« Reply #1 on: February 13, 2015, 12:05:36 PM »
There is supposed to be a nipple there for the hose to attach to. You can repair that area with a plastic hose fitting from your favorite big box hardware store. I found something at Home Depot, epoxied it in place, sanded, painted, and voila - nice solid place to attach the hose.
Sorry, I just realized you're talking about the hole in the floor - I thought you were describing a hole in the case. Sorry...
« Last Edit: February 13, 2015, 10:17:36 PM by sah62 »
Scott Hollenbeck
2019 Lincoln MKZ 3.0T AWD
2003 Mercury Marauder 300A
(more non-Ford stuff)
« Reply #2 on: February 13, 2015, 06:32:05 PM »
70 ragtop in shop has formed drain hose with red stripe & sticks thru floor about 1'' or so & round factory punched hole about 1''  no gromment
Offline twister428
« Reply #3 on: February 13, 2015, 08:59:19 PM »
My Mach 1 does not have a grommet either. Has an S shaped hose and the hole is 1" in diameter. Built March 1970.
Offline machm1970
« Reply #4 on: February 15, 2015, 10:52:20 AM »
Thanks guys!
Re: 70 A/C evaporator hose
« Reply #5 on: February 15, 2015, 05:49:07 PM »
Matt might help next time to include what your your asking about ;)
Changed the header for you
