Author Topic: Trans colour  (Read 1243 times)
Offline V8_bloke_28
Trans colour
« on: February 04, 2015, 01:49:05 AM »
Hi
What is the original trans colour for my 67 fback 390 c6 build late June 67 in San Jose?
Also what colour should the trans cross member be?
Cheers
Re: Trans colour
« Reply #1 on: February 04, 2015, 01:57:16 AM »
Which transmission?
Basically the same for all classic years (FMX is a combination of both)
Both were finished the same way (both bare metal)  but of course one would be bare cast steel and the other bare cast aluminum
There are a number of treads related to cleaning and refreshing aluminum cases here on the site
As for the transmission cross member for a 67 most would like to see bare steel  ::)
Offline V8_bloke_28
Re: Trans colour
« Reply #2 on: February 04, 2015, 02:51:38 AM »
Thanks mate
It a c6 auto.
Could I sand blast it lightly?
Cheers
Re: Trans colour
« Reply #3 on: February 04, 2015, 04:28:04 AM »
Sand blasting even lightly will change the texture of the outer surface and produce a mono tone finish. Unlike the original finish.
Read the threads for other options members have found success with
Offline 1969 Cale II
Re: Trans colour
« Reply #4 on: February 16, 2015, 11:14:43 PM »
If you have any kind of metal finishing shops near you try this. I found a shop that does different kinds of metal cleaning/shot tumbling. I had them clean the bell housing on my fmx, they glass beaded it then tumbled it in steel shot. After that I coated it with RPM and it turned out fantastic. Even did it to the power steering pump bracket. PM me if you want more details, I could give the number to the shop and he could tell what to look for.
