Author Topic: 289 hipo head information  (Read 3186 times)
priceless
  • Guest
« on: February 01, 2015, 10:57:53 PM »
Do all 289 hipo heads have screw in studs?  And do all 289 hipo heads have a 19 cast into the head near bottom corner of head and visible with valve cover on?  Do they have other numbers like a 21, 22?
What does the 289 with two dots represent?
Any help appreciated.
Re: 289 hipo head information
« Reply #1 on: February 01, 2015, 11:20:04 PM »
289 with 2 dots casting is a hi-po head.  I couldn't say absolutely for sure on screw in studs, but that would be to account for some one-off race cars or something like that.  K codes were the only Mustangs off the regular assembly line with double dot castings on the heads and screw-in studs.
priceless
  • Guest
« Reply #2 on: February 01, 2015, 11:43:47 PM »
Would a C3OE-B, E, and F, not be a 289 hipo?
And does the hipo head have the "19" always?  Do the C7 hipo heads have 19, 21 numbers and also do they have the 2 dot?
Gets confusing. The reason I'm asking a friend lead me to a gentleman that has a bunch of heads thats been lying around inside a shed. I've not been able to get over there yet. He is wanting to sell them and says a lot of the heads are Ford and he remembers C3OE marking and also has some C8AE markings. He mentioned several more but the C3OE got my attention.
« Reply #3 on: February 01, 2015, 11:51:29 PM »
Yes.
That's the mold number and 19, 20 and 21 were used.
It's an additional identifier. The casting part numbers are C4OE-B, C5OE-A and C7ZE-A. The last was the smog head. For some reason the service heads, C8ZE-B did not have casting numbers, 19, 20 and 21.
Per Mannel and Gregory.
Offline sgl66
« Reply #4 on: February 02, 2015, 12:20:10 PM »
Hipo heads also had pockets cast around the base of the spring and narrow slots for the push rods therefore not requiring guideplates.
I know guys who have added screw in studs to regular heads so don't recommend that as a 100% confirmation...it is really hard to add metal to castings so would focus on that instead  ;)
« Reply #5 on: February 02, 2015, 02:22:49 PM »
...........I know guys who have added screw in studs to regular heads so don't recommend that as a 100% confirmation...it is really hard to add metal to castings so would focus on that instead  ;)
+1 plenty of times
Go with the 19-21 when the valve covers are on - with them off casting features IMHO
