Not quite there yet.. Might have time to install in the next few weeks and will try to get installation pics for everyone to reference. I re-cleaned and re-taped the used harness just because I'm that anal.
It should work fine and thanks again Midlife!
One issue I'm having now is that the tach is showing the "clear" light instead of the green light as on the clock side. I have put back the blue covered light diffuser (I guess that's what you call it) so I'm clueless how it's not the green light I have been told it should be (thanks Charles). I will say that the clear plastic cup that goes around the bulb inside the tach is half gone from heat and age. Not sure if that is the culprit?? I'm thinking it could be as the light is much brighter on the tach side and now, not sure how to correct this as they do not offer a replacement.
Can anyone tell me the correct assembly of how the tach goes back together as I put it back the way I took it apart. ie tach housing, rubber gasket, tach lens (but I'm can't remember how the beveled edge goes??), tach rally pac housing.. Any suggestions??
