Author Topic: Cloth tape  (Read 10637 times)
Offline ChrisV289
Cloth tape
« on: January 23, 2015, 10:40:23 PM »
While I had the fastback fiberglass panels out I snapped some pictures, and was curious if the factory added that piece of cloth tape or if the 2nd owner did that:
2009 V6 Mustang Coupe
Re: Cloth tape
« Reply #1 on: January 23, 2015, 10:47:45 PM »
Factory  -
Not always that loose or exactly covering all that (likely IMHO not a precut section)
Offline ChrisV289
Re: Cloth tape
« Reply #2 on: January 23, 2015, 10:57:19 PM »
Thanks Jeff.  Here's the other side:
Offline JKWilson
Re: Cloth tape
« Reply #3 on: January 24, 2015, 12:07:02 PM »
Chris here's a pic taken during disassembly of my '66 Dearborn coupe. The tape is in a little rough shape (to say the least!), but obviously a continuing practice:
Offline Smokey 15
Re: Cloth tape
« Reply #4 on: January 24, 2015, 12:19:49 PM »
 Was the purpose of the tape to prevent metal-on-metal rattles when the seat was installed?
Offline ChrisV289
Re: Cloth tape
« Reply #5 on: January 24, 2015, 12:23:53 PM »
The tape is not visible until you take off the quarter panel pieces.  I don't believe it was for that purpose of preventing rattles, but could be wrong
Re: Cloth tape
« Reply #6 on: January 24, 2015, 05:39:03 PM »
Believe that particular piece (on the other side of the interior panels from the seat) was there to protect workers climbing in and out of the rear area on a fastback installing the interior. The unprotected edges of some of the metal in the interior can be a bit sharp at times. You can find the same use of the cloth/gaffers tape in other areas of the interior depending on year and model
My best guess.  ::)
Offline Smokey 15
Re: Cloth tape
« Reply #7 on: January 24, 2015, 10:04:28 PM »
 Makes sense. Thank You. I may use that idea when I am doing work on an interior w/o carpet.
Re: Cloth tape
« Reply #8 on: January 25, 2015, 10:18:49 AM »
I've seen the tape on a lot of cars, might check in assembly manual to see if any notes.
Offline mtinkham
  • That'll be easy
Re: Cloth tape
« Reply #9 on: January 26, 2015, 01:50:07 PM »
ChrisV289....I noticed the sound deadner on the inside of the rear quarters looks like it was masked during the original application...did Ford do that?  I know this is off topic but could not resist...on the east coast we don't get to see that much metal left on our cars!
Re: Cloth tape
« Reply #10 on: January 26, 2015, 02:33:56 PM »
The "sharp edge" is a by product of how the stuff was applied and how close the wand was rather than masking off. You can also get the product to sort of roll into place by applying enough material and using the pressure during the application to push the edge forward where they wanted it to stop
You can find plenty of examples where one or more edges are sharp with no overspray and the other edge much smoother
« Last Edit: January 26, 2015, 02:36:59 PM by J_Speegle »
Offline ChrisV289
Re: Cloth tape
« Reply #11 on: January 26, 2015, 03:58:46 PM »
Here is a better picture...
Driver:
Passenger:
Re: Cloth tape
« Reply #12 on: January 26, 2015, 06:22:09 PM »
Such a nice example and great condition  Chris !
Offline ChrisV289
Re: Cloth tape
« Reply #13 on: January 26, 2015, 07:55:12 PM »
Thanks Jeff.  Figured I'd take pictures since I hadn't seen that area before on this car.  Interior is mostly original except the carpet was changed out and the 2nd owner must of had that black sealer sprayed in on the floorboards  :(  I had it all out to put the correct style carpet in that stops at the floor board.
Finished product:
« Last Edit: January 26, 2015, 07:57:51 PM by ChrisV289 »
Offline DM_1964
Re: Cloth tape
« Reply #14 on: January 27, 2015, 01:34:10 AM »
Finished product:
Job well done, looks fantastic!
Regards,
Dom
